Old 01-31-2015, 07:04 PM
Had my brand-spanking new steering pump installed, the guys said it didn't change the noise much. It seems the previous pumps may have corrupted my steering rack.
Sourced a clockspring.
Still looking into radiators. Want to get a cheap OEM replacement while I figure out if my PWR can be repaired.
Still waiting for Tomfiles to come out of hiding. Anyone heard from him?
A good rad shop SHOULD be able to solder a PWR as long as they clean it first!
Old 02-01-2015, 11:37 AM
Gamesy's Avatar
Gamesy Gamesy is offline
parked the svx (due to cracked block from water pump)
swapped the winter tires onto the sti,
fixed the hids and horn relay on the sti
Old 02-03-2015, 07:54 PM
Reign1979 Reign1979 is offline
Put my halo lights in
Old 02-04-2015, 06:04 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Nice looking!
"Peace is the flower of justice."
Old 02-04-2015, 07:16 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Removed comment to another thread, sorry.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 02-06-2015, 12:23 AM
Thanks! Wasn't too hard. Went to eBay and $10 later had some
Old 02-15-2015, 08:00 PM
steamer99's Avatar
steamer99 steamer99 is offline
My wife was using it for a driving lesson for my daughter and it blew the low pressure power steering line. Fortunately the one on my parts car was still good, it sure was a lot easier to take it off the car that does not have a transmission but I got it swapped over so I can still drive it to work tomorrow
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
Old 02-15-2015, 08:14 PM
Looks great! I like the look of halos on the SVX.
Old 03-11-2015, 12:10 PM
Hit 100k miles on monday.
Tuesday bought an 85 buick t-type regal for the wife to daily drive (she was daily driving the svx) so i could drive it to work every day and start sorting out it's small problems.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 03-11-2015, 12:23 PM
dannmarr's Avatar
I work for my SVX
Need to replace both front axles. The car was in a trans shop for a year and new axles were installed. I drove it for a few months and the axle boots are torn?
I wonder if they were ever changed. I should have checked. Kicking myself
Subaru SVX for fun
Old 03-11-2015, 12:31 PM
If they are green then they are Subaru axles, if they are green and rusty then most likeky they are the originals.
If they are shiney and steel/silver then most likely they were replaced.
T
Old 03-11-2015, 08:59 PM
dannmarr's Avatar
I work for my SVX
T
Thanks! unfortunately they were replaced once before, so I dont know if they were replaced now. The trans shop owner is a nice guy but is disabled and his dad, the master mechanic retired. Now he has these young inexperienced guys working in the shop. So, who knows?
Subaru SVX for fun
Old 03-15-2015, 01:51 PM
theflystyle's Avatar
Vacuumed the mice droppings from my engine bay
Thankfully there was nothing inside the car from what I could tell. It looks like it/they liked running around on top of the battery as it was connected to a trickle charger and must have been the warm spot.
Side note - I need to find a way to close the gap between the garage door and wall. Some sort of vertical sweep maybe?
1994 SVX LSi
2008 Legacy 3.0R
Old 03-15-2015, 02:02 PM
gwynethh's Avatar
We tried one of these during the winter for under the hood
http://rid-a-rat.com/
Should be able to check how well it worked any warmer month now.
We place some organic (ceder?) packages in the car also. As a plus it smells really nice for a long time.
Old 03-17-2015, 02:24 PM
INVADR's Avatar
INVADR INVADR is offline
Pew Pew!
I finally got around to installing the MAPvss speed signal converter. Ever since I swapped in an 08 5-speed, I haven't had a working speedometer/odometer. This unit picks up signal from the ABS wheel sensors, and turns it into a pulsed VSS signal. Works awesome!
Still getting an ABS light, though. Might have a loose connection at a splice point. I need to figure out how to read the ABS codes.
Mark S.
1995 LSi, EPM, #1152, 197k(ish) miles, 5-speed
