Old 01-19-2015, 11:28 AM
Today I am searching for a replacement of the replacement driver side heated mirror that went missing after a particularly nasty roommate moved out.
I am contemplating buying a Class Glass hood , checking around for new or used electrically-controlled power steering pumps , getting a tally on driver's side fenders since my body shop apparently didn't order one , and trying to figure out how to access the connection in the steering column which prevents the horns, cruise, and SRS from working.
What else? Right, I need to remember how to repair my automatic shoulder belt. I cranked it all the way back manually but it just retracted again.
Old 01-19-2015, 12:03 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Remove the Air bag (4 T-30 or T40 security bolts (the ones with a hole in the center)), remove the steering wheel. Investigate the "clock spring" and connectors in the round plastic container.
"Peace is the flower of justice."
Old 01-19-2015, 12:20 PM
MR2 pump? Inquiring minds want to know!
Old 01-19-2015, 12:54 PM
I am looking only for SVX parts.
That's what you meant, right? Maybe I mean electronically variable, I was never really clear on how the steering systems vary.
Thanks big, appreciate.
Old 01-19-2015, 04:58 PM
Ah, gotcha. Thought you might have meant an electric powered hydraulic pump.
Old 01-19-2015, 05:22 PM
CAUTION! Disconnect the battery for at least ten minutes before you unplug ANY SRS yellow plugs or removing the airbag.
And secure the steering wheel so that it does not spin freely if you disconnect it from the rack.
Old 01-19-2015, 05:40 PM
Gamesy's Avatar
Gamesy Gamesy is offline
installed block heater and replaced lower rad hose
also finally put back the skid plate
Old 01-19-2015, 06:20 PM
Old Davy's Avatar
Old Davy Old Davy is offline
Had the SVX out for a spell of chores while the Outback was in for a new exhaust pipe back of the cat. I cracked the joint plowing through a frozen snow berm at the foot of the driveway two days previous. Parts ordered same day work completed by noon on Friday
Well, the SVX needed a photo op as well as a monthly run so over to F.A.G. Aerospace building for an unmistakable multi-message Winter photo. Washed and put away in garage until next month.
Cheers, guys.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 01-19-2015, 07:17 PM
Good advice. Battery has been disconnected for months.
Never thought about the securing the wheel. getting it straight again sure is a pain in the rear.
Old 01-19-2015, 07:31 PM
If you disconnect the steering column from the rack the wheel can spin, unwinding the clock spring, resulting in the snapping/breaking of said clockspring.
Old 01-19-2015, 10:22 PM
Thumbs up
And I bet that is exactly what happened! How boned am I if this is broken?
Old 01-20-2015, 02:24 AM
Buy a new clock spring.
Hey Nate...
Old 01-23-2015, 08:50 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Just sold the SVX to a coworker today.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-26-2015, 09:06 AM
gwynethh's Avatar
Finished some work on our clear corners and rear center lights.
Removed the orange cup from inside the JDM clear corners and sanded and clear coated the lens using Sylvania headlight restorer. Photo attached. We will be using a bi-color leds (white and orange) for the bulb.
Partially de-badged a spare rear center light assembly. Also sanded and clear coated the lens the same as the clear corners. Photo attached. We made our own internal "SVX" decal though you can find better ones from Retroroo http://www.indysworld.com/decals/. Photo attached below
We also hope to do the same to the rear brake and side rear side marker lenses sometime
Old 01-26-2015, 10:10 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
I autocrossed mine yesterday and either beat or matched most of the STIs' times.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
