#1726
Broke my Outback in!
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 03-23-2013 at 01:49 PM. |
#1727
Took the SVX out of hibernation today! And then made a complete tool of myself. The car started perfectly with a boost, let it idle for a few minutes and then drove to the gas station. As soon as I walked around to the pump I realized I'd forgotten my wallet. Then when I hopped back in the car I discovered the battery hadn't charged enough to start the car. ****.
Walked home (10 mins), got the Elantra and booster cables, boosted SVX and drove it home, walked back to gas station, drove Elantra home. I'll take it for a longer drive tomorrow and see if things charge up properly. If not the battery is under warranty. It's so much fun driving the SVX again though. And quite tricky. I'm used to the Legacy now and the SVX drives extremely differently. Way more touchy throttle pedal compared to the Legacy, and also much more low end torque. All together it's a much different driving experience.
#1728
Hint. Get a jump start battery pack.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
#1729
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#1730
Outback limited leather steering wheel, still working on getting the airbag wired up.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#1731
Loaded the battery and started her after six months in garage.
svx my94 vtd EUDM -custom Spax coilovers Last edited by Chris_; 03-24-2013 at 06:48 AM. |
#1732
Wow!!! man what's up with those "back to the future wheels"
Is there enough air getting to your brakes??? |
#1733
svx my94 vtd EUDM -custom Spax coilovers |
#1734
Took the "Pearlie" to Vegas this weekend. First road trip in it since I bought it (three weeks ago). Drove like a dream! And 28 mpg!
ARMANDO 1992 SVX LS-L "Black Beauty" 292,500K (purchased April, 1997 w/65K) http://i1259.photobucket.com/albums/...psz1xmhtdo.jpg 1992 SVX LS-L "Blanca" 214,000K http://i1259.photobucket.com/albums/...pskv0odesa.jpg 2004 Mazda RX-8 http://i1259.photobucket.com/albums/...ps7vggfwfu.jpg 1974 Mazda RX-4 http://i1259.photobucket.com/albums/...psentjrygb.jpg |
#1735
#1736
I noy mentioned the battery pack so it would have saved you a lot of driving and walking time. I keep one in my trunk.
Best $59 I spent in years.
#1737
Best product I have ever used to keep my battery charged between drives. And for jump starting anything, I keep this 900A Battery Pack in my car. I has started 3 totally dead cars in succession without missing a beat. During an emergency, this will keep your cellphone powered for weeks. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-25-2013 at 09:33 PM. |
#1738
Bench tested my new double-din receiver and HKS CAMP configuration so I can listen to audio from my Zune while viewing the CAMP output all while the car is in motion.
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#1739
Wow! And I thought I was the only one who still used a Zune! Do you have it hooked up through the AUX port or do you control it through the head unit?
#1740
I have one of the zune hd's, had it for years and still use it.
