Old 02-15-2022, 02:49 PM
gringo gringo is offline
Re: After aceleration, cars turns off
Originally Posted by Trevor View Post
The engine should keep running at idle speed after any throttle position even when cold, when properly controlled by the electronics. Research here for posts covering idle setting and control problems for detailed information.
Dear,
My mechanic tested the voltage of the TPS, and it´s all right.
He is guessing that the problem is the Ignition Control module 3.3L J716 22438AA050, or the Crank Position Sensor.
What is your sugestion?
Old 02-15-2022, 03:35 PM
It doesn't sound like a crank position sensor issue. They usually cause a no start scenario.
Old 02-15-2022, 04:33 PM
The iddle speed is around 500 rpm when it´s cold, sometimes it´s turn off.
There is a atrong smell of cathalytic converter when it´s cold.
And the problem after full throttle, I leave the pedal and it turns off.
So sad.
Thank you guys.
Old 03-24-2022, 07:58 AM
Guys, I found the problem, it was the ignition module.
part number: J716 22438-AA050
Old 03-24-2022, 03:37 PM
Thanks for the update and solution.
