Old 03-01-2016, 08:31 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
"How To" for power Mode switch addition
As it says above, has anyone done a "How To" doc for this mod ?.
Just that it is really hard to find some actual "short" info (with photos).
I have a couple of OEM "Power" switches from JDM models and want to add to my NZ new 94 LSi.
thanks
Steve in New Zealand
Old 03-02-2016, 07:10 AM
radarwhiz's Avatar
Fairmont State University
Re: "How To" for power Mode switch addition
http://www.subaru-svx.net/forum/show...power+mode+mod
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 03-02-2016, 03:19 PM
SURTEESS's Avatar
Thanks for that - hopefully it is the same for AUS/NZ models?.
Old 01-22-2019, 02:56 AM
SURTEESS's Avatar
Well my NZ new 95 model must NOT have A4 connected to the module internally - as I do not get the power light coming on when pin A4 is shorted to GND ?
So now I need to remove the module and swap it out with a JDM version ?.
Anyone else had a similar issue ?.
Anyone know where / what components are connected to pin A4 within the module - that way I can conform by opening up my module to check what is missing?.
TIA
Old 01-27-2019, 03:46 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Australia/NZ model has a similar TCU to the UK model. Pin A4 activates "Economy" mode not Power mode.
If you want a power mode switch for that, you have to chip the TCU. I did a few of these for people a long time ago, but I don't have the time anymore.
As far as I remember, a JDM TCU won't work because the front speed sensor is different. Plus there are C solenoid differences pre and post 1995. People have overcome these problems, but it's not a easy swap.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-27-2019, 04:12 PM
SURTEESS's Avatar
Phil,
Yes you did a ROM for me about 6 years ago - finally just put it in, it works a treat (well the power light works fine) - many belated thanks.
Now just got to get all the interior stuff back in so I can take it for a drive.
Old 01-28-2019, 05:12 PM
SURTEESS's Avatar
Interior now back in the car - just took it for a drive.
WOW what a difference the POWER mod makes, together with the Gear Firm-Up Unit.
Take off at lights is way quicker than "normal" driving mode, it goes nearly to red-line before changing - then the gear change is super slick with no time-lag.
Will take it out on highway later tomorrow.
