#2611
Found true blue posing in her favorite spot for a (spring) photo shot.
https://www.dropbox.com/s/0l3iob0g6f..._5363.JPG?dl=0
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi My fast baby: 2001 Suzuki Marauder My new baby: 2010 Subaru Outback |
#2612
Very nice.
#2613
Got windows tinted, new remote system (that I immediately hate), and finally wired up my reverse lights to work when shifting into reverse as opposed to a toggle switch (remote install guy hacked up my wiring).
Right now I am trying to move my Supertones from within the engine bay to behind the waterfall. This is also the first time I have ever removed my the waterfall.
#2614
Go to SVX INFORMATION WAREHOUSE
Look for the SVXIpedia link on the top of the page. Click. Go to Checking Error Codes. Third from the top. Click. How to Check ABS Trouble Codes is at the top of the list. Or just go here for the printable version: http://www.svx-iw.com/svxiw/article/...php?article=80 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-11-2015 at 11:10 AM. |
#2615
Started reassembly of the intake manifold. Attached the painted fuel lines, throttle body and various other bits. Started attaching the viton vacuum hoses as well.
OT - Thanks for the IRIS o-ring. She fit beautifully
#2616
So clean and pretty. Looking good flystyle.
Today on mine I exchanged my Autozone alternator which had a slightly damaged post and installed the replacement alternator. Also installed my new OEM #1 coil which fixed my misfire.
#2617
Picked up a little something for the Legacy... One of my stock calipers seized up and this wasn't significantly more expensive than a set of remans.
#2618
I got my car back with two new front axles. Next project is to fix the rear wiper motor, it keeps blowing the fuse.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#2619
Had to replace a cracked cyl. 3 exhaust valve in the Forester which is why it was only holding 30lbs of compression.
#2620
I love building custom parts for the SVX, but every now and then it's nice to be able to just bolt something on to the car. Brembos are fun!
#2621
Getting my Ceikas installed today.
#2622
Expensive little venture, I presume ? Is there a post that lists the parts needed and/or a How To?
Thanks |
#2623
If you're talking to me, yes it is expensive because I am paying someone to do it.
I'm 'bout dead broke now.
#2624
Installed the painted cowl & wiper bits back onto the car
#2625
Picked up a little JDM goodness for the ol' RallyRex.
Version8 VF37 twinscroll.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
