Old 01-26-2015, 12:22 PM
Stocked up on oil for the Legacy. With a commute of 130 km (80 miles) per day I buy in bulk.
The oil in the car is going in for analysis to see what sort of change intervals I can get away with. If I can get 12-15,000 km per oil change one barrel should last me 18 months.
Old 01-26-2015, 09:35 PM
Tapani Tapani is offline
I replaced the o-ring at the base of the oil filler neck.....
... do you guys know if the seal on the filler cap itself can be bought separately or do I have to order the whole cap? It feels a bit hard and it seems the small oil leak I thought was the cam cover corner actually come from either the filler neck base o-ring or the cap seal.
/T
Old 01-28-2015, 11:09 AM
EdWindows's Avatar
5spd + coilovers = win :D
How much savings over buying quarts or gallon jugs?
Old 01-28-2015, 05:57 PM
michael's Avatar
michael michael is offline
What Potholes ???
Not sure if you have junk yards in Finland but you can use a cap from any suby.
edit: almost any 1990's and up suby.
/T
Wanted: Steering Wheel
Old 01-28-2015, 06:19 PM
I got the bucket on sail for $127 so it worked out to about $6.75/liter. A normal 5L jug costs close to $50, so $10/L. The bucket should be good for 3 oil changes + top ups.
Old 01-28-2015, 08:28 PM
Took the car in to get the brand spanking new steering pump installed. On the way I remembered my $700 radiator leaks. Not sure if I want to try to repair it or just get another one.
Buy a new clock spring.
Hey Nate...
Does Nate have one because the dealer can't get me any and my mechs aren't having much luck either.
Also I sent ya 2 PMs regarding the hood.
Old 01-28-2015, 09:04 PM
Not sure Nate checks this site much. Try him on Facebook.
Old 01-28-2015, 09:39 PM
I would but he unfriended me. :P I need a liaison.
Old 01-28-2015, 10:38 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
Hey, that's the same stuff I put in my Cummins (or Mobile 1)
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 01-29-2015, 09:17 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Originally Posted by gwynethh View Post
Finished some work on our clear corners and rear center lights.
Removed the orange cup from inside the JDM clear corners and sanded and clear coated the lens using Sylvania headlight restorer. Photo attached. We will be using a bi-color leds (white and orange) for the bulb.
What method did you use to remove the orange cup from inside the JDM clear corners?
If you used the oven method what temperature and how long?
I've wanted to do this for a long time, BUT since the JDM corners are not exactly growing on trees I'm afraid to mess them up!
The "bi-color leds" are actually called Switchback's.
Will you be using 60 or 120 leds?
Sam
Old 01-30-2015, 06:25 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Brothers hot air gun (used to heat shrink RC airplane wing plastic) and very SLOW twisting pressure with a wide blade screwdriver and a 1" metal spackle blade to prevent distorting the black plastic. There is a "how to" some where and Smallcars has instructions (don't forget the metal pins). The cups came out easily (memory fails from when we removed them a bit back, twist lock? held in by the bulb reflector?)
Don't remember on the LEDs (they are on the oem corners now and in winter storage. Plenty bright in ant case.
"Peace is the flower of justice."
Old 01-31-2015, 06:01 AM
michael's Avatar
What Potholes ???
I used a propane torch. put it on "very low", heat up the cup till it's mushy, jab a pair of needle nose pliers thru it, twist and pull it out. No need to take the lens apart.
Old 01-31-2015, 07:50 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I just wait for Advance Auto sales. They usually have deals like 5 quarts of synthetic with an oil filter for $20-25. I stock up for the year on all my cars. I also have a valve drain plug on all my cars, it makes oil changes a breeze.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 01-31-2015, 01:38 PM
Had my brand-spanking new steering pump installed, the guys said it didn't change the noise much. It seems the previous pumps may have corrupted my steering rack.
Sourced a clockspring.
Still looking into radiators. Want to get a cheap OEM replacement while I figure out if my PWR can be repaired.
Still waiting for Tomfiles to come out of hiding. Anyone heard from him?
Old 01-31-2015, 07:02 PM
On Monday I will check on shipping to Washington.
