Reading 16 signup list
If you are planning on attending the Reading 16 "It's all about the people" Meet, add your name to the list. If you are staying at the hotel, also add your names to the "Rooms Booked" thread HERE , along with the dates and type of room reserved. This will make it easier to keep track of the block. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-24-2015 at 09:07 AM. |
Re: Reading 16 signup list
1. svxcess
2. radarwhiz
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
1. svxcess
2. radarwhiz 3. subeman90 would hate to miss it
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7.green_eyed_lady
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 09-22-2014 at 10:44 AM. |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7.green_eyed_lady 8. Subbyru89 9. Hocrest
No one is committing to rooms yet? You need to reserve rooms and types early so we know what is left in the block and what we may need to add.
That thread is HERE .
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate 11. jellybytes
'97 SVX 'Brilliant' Reddish '94 SVX Lagina '93 SVX Less Reddish '89 XT6 '08 Impreza '18 Crosstrek Totaled '98 LGT ~180K '97 OBW ~185k '93 SVX Less Reddish Sold '89 XT6 '04 VDC Sedan Parts '89 XT6 '96 SVX |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate 11. jellybytes 12. te_w |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate 11. jellybytes 12. te_w 13. SVeXY96
Meow |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate 11. jellybytes 12. te_w 13. SVeXY96 14. Larry III & the beautiful 'Naviguesser'
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate 11. jellybytes 12. te_w 13. SVeXY96 14. Larry III & the beautiful 'Naviguesser' 15. rvnmaniac + 1
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
1. svxcess
2. radarwhiz 3. subeman90 4. Huskymaniac 5. Sean486 6. svxfiles 7. green_eyed_lady 8. Subbyru89 9. Hocrest 10. 1986nate 11. jellybytes 12. te_w 13. SVeXY96 14. Larry III & the beautiful 'Naviguesser' 15. rvnmaniac + 1 16. ddmd |
