Old 05-02-2014, 08:31 AM
Temp gage
I have a Tranny temp. gage that is no longer connected to the tranny as the auto was replaced with a standard. So I now I have a non functioning gage. Here is my dilemma , what can I use the gage for now? Any suggestion on what I can connect it to and how? it is in a 3 gage cluster mounted in the old DVD slot under the radio.
Old 05-02-2014, 09:27 AM
Tapani Tapani is offline
Re: Temp gage
You can install a temp sensor in the drain plug of:
  • Engine oil
  • Front diff oil
  • Rear diff oil
  • Manual transmission oil
Then get a four way selector switch and you have access to all your oil temperatures.
Or even drill and tap the thermostat cover and monitor radiator exit temp
Tapani
Old 05-06-2014, 04:36 PM
NiftySVX NiftySVX is offline
Send a message via AIM to NiftySVX
Re: Temp gage
I would actually be curious about the oil temp of the front diff.
2007 GS 450h-Active Stabilizer/Radar cruise
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Toyota Master Diagnostic Technician (former life)
Old 05-06-2014, 05:02 PM
Re: Temp gage
Where would you attach the sensor? I like that idea.
Old 05-07-2014, 01:07 AM
Re: Temp gage
First remove , then drill and tap the drain plug.
Old 05-07-2014, 02:19 AM
Re: Temp gage
See attachement
/T
Old 05-07-2014, 03:39 PM
Re: Temp gage
Any lead on where to get the sensor?
Old 05-07-2014, 08:14 PM
Re: Temp gage
It has to be compatible with your gauge - so try the manufacturer.
I drilled and tapped (1/8 NPT in my case) the plug myself, but you can buy these too. The NPT thread is conical so you need to pay attention.
Tapani
