Old 10-10-2013, 11:26 PM
bishop bishop is offline
un plugged plug, need svXperts help
So I was under my car today investigating a knock coming from the passenger side front wheel and doing a general inspection.
Found an un-plugged plug on the driver side, bundled with the o2' sensors wiring, anybody know what this thing go to? little grey/white plug with 2 prongs, is it just on there in case the car had the speed sensitive steering rack or something?
Thanks everybody
Old 10-11-2013, 06:02 AM
Re: un plugged plug, need svXperts help
Found an un-plugged plug on the driver side, bundled with the o2' sensors wiring, anybody know what this thing go to? little grey/white plug with 2 prongs, is it just on there in case the car had the speed sensitive steering rack or something?Thanks everybody
Yes.
Does your SVX have a sunroof, and thereby speed sensitive steering?
Old 10-11-2013, 10:45 AM
Nope. thanks for answering that.
Now does anyone have ideas for why i get a clunk when backing up right and hitting the brakes?
Old 10-12-2013, 11:28 PM
Does the "clunk" sound like its low in the car,
on the passenger side,
and only do it once after the car has been started?
Old 10-13-2013, 01:58 PM
Passenger side front wheel is what it sounds like, checked all the brakes and suspension point and they are all good except for the front sway bar bushings which I already knew. I did find that the transmission was resting on the torque bar under the diff.
Old 10-13-2013, 02:33 PM
The front diff is resting on the torque bar??
Check the thickness of your engine mounts.
They SHOULD be round if stock and just under 2.5" thick.
If the rear/transmission mount is good,
the over all thickness of the paralell metal plates should be 1.5".
Old 10-13-2013, 03:36 PM
The bar was bent up slightly and im using aftermarket engine mounts that moved everything down slightly. Bent the back down so it clears, havent heard the noise for a little while.
Old 10-13-2013, 04:31 PM
Cool.
What mounts did you use?
Old 10-13-2013, 04:53 PM
https://www.revshift.com/shop/motor-...-1993-2010.php
they were included with smc's engine.
Old 10-15-2013, 07:21 PM
How thick are they, from mounting faceto mounting face?
