Re: SVX for SALE!
$2500 for head gskts, bolts, water pump, timing gear, etc .. I assume he did. I overheated on test drive.. for 5 miles after engine install (air pocket?).. sent to CA from PA. Worked good otherwise.. no oil leaks at all. Ultimate Bummer! Marriage .. or head gasket engine out/in? This burned me out. BARR'S Head Gasket Fix sounding better now in this mess..Bought it last year.. but decided to get "rebuilt" low mileage engine.. Now, same head gasket leak I had to start with!!!
