please clarify svx calipers on a gc8
my friend is convinced that the svx calipers can bolt onto a gc8, can anyone clairfy being true?
i would check this myself but i am nowhere close to my svx
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... Last edited by Gamesy; 07-28-2013 at 03:01 PM. |
Re: please clarify svx calipers on a gc8
Grandaddy of all WRX's GC8 = 1992-2000 Impreza sedan 2.0L Turbo G=Impreza C=Sedan M=Coupe F= Wagon 8=2.0L turbo 6=2.5L NA .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-28-2013 at 08:01 PM. |
-_-..... i meant any G series impreza lol
I believe they should.
GC8 four piston front calipers bolt onto the SVX. SVX calipers should bolt onto the GC8. Sourcing the correct rotor to use would be the next issue to take on, though.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX 1994 Legacy GT 2001 Forester 2002 Impreza WRX 2005 Impreza WRX STI Need parts? |
Edited my original post to read 1992-2000 (instead of 1999-2000). Sorry, ipad typing sucks.
Grandaddy of all WRX's GC8 = 1992-2000 Impreza sedan 2.0L Turbo .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
well thats interesting, my friend is wanting me to buy his 6pot xyz bbk for a gc8 and the rotor is dual bolt pattern. now i wonder if that rotor would still fit
I've bolted STi Brembos into my SVX before. The bolts will fit, but that's the end of the story. STi rotors won't fit an SVX, and vice versa. The caliper mounts farther out on an SVX and necessitates a larger diameter rotor. The SVX also has more rotor offset (the hat section is taller). Also, plan on going up an inch in wheel size from the minimum fitment on his car (ie; if he can get away with a 17", you'll most likely need an 18). Brembos on an SVX don't fit under STi BBS rims, they need 18" wheels.
No, sorry. I know that we have more built in because my Rota Grids clear the Brembos, while the STi guys need a 5mm spacer with those rims. The difference is in the 5-10mm neighborhood.
