Old 06-24-2013, 09:29 AM
Huskymaniac's Avatar
Uses the ignore feature
ECU/TCU reporting low RPMs
I "think" the tach is accurate and the ECU is reporting low. I assume this is a sensor issue. Anyone ever have an issue with it?
Tony
Old 06-24-2013, 10:15 AM
Tapani Tapani is offline
Re: ECU/TCU reporting low RPMs
Pls explain - how do you mean "reporting"?
/T
Old 06-24-2013, 10:19 AM
Over the select monitor. I am using JECScan to read the ECU/TCU parameters.
Tony
Old 06-24-2013, 10:22 AM
Error in the definition formula converting the hex to real numbers ?
I had this with the ECUTuner.... ECU and TCU erev numbers were not the same....
/T
Old 06-24-2013, 03:16 PM
/T
The ECU RPM calculated by the ECUTuner matched the tach gauge when I messed with it. I would bet that it's a calculation error too.
Husky, when you say that you think it's a sensor issue, do you mean crank/cam sensors? I don't think that an issue with those would allow the engine to run, but report the wrong RPM.
