Smashed my front suspension
In a combination of stupidity and bad luck I curbed in around 40-50kmh and smashed my right front wheel. The rim lost a good portion of metal and from what the retrieval guy could see, the carrier arm was broken. After bouncing out from the curve I managed to drive the car some hundred meters where I parked it.
It's taken to the shop but there's no knowing what's actually damaged, if there's damage to the frame or "just" some arms and joints. The wheel is skewed and somewhat pushed into the rear end of the wheel well.
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: Smashed my front suspension
I did that to a Chevy Corsica when I was 16... Took a turn at 30mph slide on some sand plowed right into a curb, it looks so mangled..
The control arm, tie rods, and other misc thing broke taking most of the impact.. no frame damage. I hope your SVX is ok! |
Thanks!
What concerns me are some small recesses in the roof at the corners of the sunroof cutout. I swear I havent' seen them before. Looks like subtle, machined dents....
In the roof!? from hitting your wheel?
There is no visible damage whatsoever on any body panel that I could see. I hit with the front wheel first, then the rear wheel slammed in but with only some chipping on the rim and tire. I don't know how the forces where distributed throughout the vehicle's parts and if they reached the frame at all.
the sunroof was open when it happened if that matters.
How is the alignment of the other body panels? Fender/hood/door/quarter panel? In my young and stupid days I did the same to my parents' Forester. Despite destroying the rim the car drove perfectly straight with the spare on. The bill ended up being ~$2000, new wheel/tire/control arm, labour, and alignment. My brother then did likewise to their other Forester, except he mangled 3 corners of the car. Like I said, young and stupid. Now I only break my own cars.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 05-24-2013 at 10:39 AM. |
Well, it's just stupid here
![]() They (marque garage) came up with this parts list: 20200PA100 Lower Arm Assembly, Front Right 20220PA000 Ball Joint Complete 28012PA010 Housing Front Axle, Left 28016PA000 Bearing-Front Axle 28015PA000 Oil Seal - Front Axle, Outer 26750PA000 Tone Wheel - Front 28052PA000 Hub Complete - Front Axle 28015PA010 Oil Seal - Front Axle, Inner 031478000 Snap Ring, Inner So basically, this last portion is pretty much hub, bearing and the seals to go. But is this a complete list? I seem to remember there was more to it? The three upper, is it correct with Left housing when the damage was done on the right side? So with the lower arm assembly and the joint, may I presume that nothing else actually broke? They estimated five hours + alignment.
I guess you are not:
jetboy Very Terrific Driver anymore. |
I've fixed one with the exact same damage, a used lower control arm, and a new rim (and an alignment) is all you need....I'd try to find used first (but I know that will be rare in your part of the world) the hub and axle should be fine.
I can always ask the garage why they want to change all that, esp the hub and bearings. Obviously, the car is not going to move on it's own so it's difficult to get a second opinion.
When I check the parts through different vendors, I get a lot of "Left" and slightly different results.28012PA010 shows as "Knuckle" at one site ?!
Naaaaaate!!!!
Heaheahae that's just cracking me up. No, wait.. it was the sound of the lower control arm...
![]() Might we assume I never were a very terrific driver? ![]()
