Re: Where has my oil gone ?
Surely the easiest and FREE way to make sure your oil is not low or empty is to use the dipstick...it's worked for over 100 years.
Just saying :-)
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan. Nissan R34 Skyline Stagea 91 Lotus Elan SE Turbo 1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new You can tell the men from the boys from the speed of their toys. |
yes, valuable lesson learned.
Learned another valuable lesson last week, don't tow a nearly 2 tonne car with your ute in 5th gear. It will break the gearbox. It's been an expensive week. SVX engine Mitsubishi 4WD gearbox |
What's a glass transmission ?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
I suspected that was the case, but I didn't detect the sarcasm in your original comment and so it didn't make sense to me.
Now with my sarcasm detector properly tuned, it's obvious now. |
Nate's comment, not mine. Nate hauled a few SVXes around the country with a dodge caravan, packed full of engines, transmissions, etc, etc. Poor caravan. Those transmissions are supposed to be pretty weak.
