Engine Codes 29 and 33. Help!!!
So this morning went out to start the SVX, let it warm up (it was 15 degrees out) for about 10 minutes and was on my way to town but quickly noticed that my speedometer wasn't indicating my speed. Shortly after the "Check Engine" light came on. Also I was not able to drive faster than about 40 mph ( that's only a guess since my speedometer was not working. I drove back home and pulled codes 29 (Crank Angle Sensor 2) and 33 (Vehicle Speed Sensor 2). Any suggestions? Car was working great before this.
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
Re: Engine Codes 29 and 33. Help!!!
Was it sitting for any amount of time? My first check would be for critter nests that would have chewed through wires.
I've had the same codes on my car.
Speedo won't go above ~ 40 km/h, but car can still cruise at 100 km/h easily. Crank position sensor - dealer said it might cause problems when the car is restarting when hot or starting when cold. Can't remember which it was. Either, not especially important in our climate and I've never experienced any problems. CEL will come on the the VSS error after about 50km/h of travel. I think the error is triggered when it sees a prolonged speed difference between the two speed sensors. Sorry, doesn't solve your problem, but adds a but more knowledge to the pool |
1986nate- the car sat for 3 days in the driveway... its 20 degrees out doubt there was anything nesting but thanks for the reply
ShaneHobson- The crank position sensor would give you trouble starting in cold weather. My speedometer does not move at all. Info is appreciated though!
If the speedo doesn't move at all, and you are also getting a code for it, then I'd bet the sensor (or wiring from the sensor) is bad. What I would do is take out the sensor to check if the little thingy inside it that spins is broken or ok. And have a look at the wiring while you're there.
As for the crank sensor, if the car is starting and running and sounds normal, I'd clear the code and see if it comes back, and then report back if it does.
It's on the transmission bellhousing, near the front diff dipstick, accessible from the passenger side. The plug has 3 pins.
Here is some info about it (VSS2): http://autorepair.about.com/library/a/1h/bl833h.htm
Okay, so I finally went in and replaced the VSS2, it was visibly broken. The wiring seemed fine. Cleared the codes and took it for a spin or well I tried too, its still doing the same thing as before. Speedometer won't move at all, and when driving on "D" there is only one gear. If I use the manual button I can drive on "3" at a faster speed. Checked the codes and still gave 33 but now gave 28 which is Knock sensor #2 (LH) Abnormal voltage in knock sensor monitor circuit. Any ideas?
Okay, will do and I'll let you know how that goes. Thanks! Simple Curiosity, what if it continues with same problem after the steps you mentioned? I already checked engine and transmission fluids, checked all relays and fuses (all good)
Gear box won't change gears, if it does not know that the car is moving. It will change if the lever is used, don't need to push the "manual " button.
Yeah the manual button is not used when driving in "D" that is when gears don't change.
I did what you said sensor is fine and unplugged battery for 10 min and still same signs. I did notice that my odometer is not working either. I read on another thread that it could mean that plastic gears inside the differential are broken?
Edit - another idea: Maybe the sensor didn't get threaded in far enough for the little spinny thing at the bottom to fit into its slot?
