Need parts ASAP
I need the power steering high pressure hose
Speed sensor, front of bell housing Radio door cover And a driver side window regulator Stock cogerette lighter if you have it, lighter, not outlet If price is right a stock rear wing, mine has a chip on it And anyplace that would have some type of after market parts for this car. And an idea where to get stock struts without being insanely ripped off in price? |
Re: Need parts ASAP
What year is your car? The high-press p/s hose was changed between 92 and 94.
Also the radio door can be grey plastic, light wood grain or dark wood grain, depending on year and trim. Also you will probably want a particular color of rear wing?
Re: Need parts ASAP
Yes, black rear wing, I have a 1994 ls pearl white with black top. And it's a 94 fwd
Re: Need parts ASAP
I have a p/s hose from a 92
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree ![]() #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Re: Need parts ASAP
High-pressure PS hose changed from a 2-piece design to 1-piece. They're interchangeable though, I just put a 2-piece hose from a '92 LS-L on one of my '94 LS's and it worked fine.
Re: Need parts ASAP
Well guess mine is newer because its a one pice hose
Re: Need parts ASAP
If you post a pic I'll tell you which kind it is. The 92s have a metal tube that goes right alongside the right side fuel rail from the P/S pump to the back of the engine, and then a high pressure rubber hose that goes down to the rack. The 94s run the high pressure hose from the pump to the rack, slightly to the side of the engine. (The 94 design is easier to work with, IMO).
