Old 01-02-2013, 10:41 PM
EdWindows's Avatar
5spd + coilovers = win :D
Engine temp gauge
Is everyone's temperature gauge needle this high on the scale during regular driving? Or is it time for a new temp sensor?
It reads this high ever since I bought the car. There's no coolant leaks, no other noticeable heat problems, and ambient temperature hasn't been over 40*F for the past month or so.
Also, car usually idles around the RPM shown when in neutral, but I figure that's probably my bad TPS.
Old 01-02-2013, 11:39 PM
Re: Engine temp gauge
That's perfectly normal. That's where both of mine sit normally.
Old 01-03-2013, 03:56 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
My temp is always on the dead middle.
I didn't try neutral but idle at between 500-900, depends how long I've driven. Generally lower when properly hot.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 01-03-2013, 06:40 AM
Looks like mine. Where did you think it would be? I do not get good heat from the heater til it gets that high.
Old 01-03-2013, 07:37 AM
jetboy's Avatar
I gathered teh idle speed of this engine at operational temperature is supposed to be around the 500 mark? Does this say anything about the engine's health?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 01-03-2013, 08:59 AM
EdWindows's Avatar
Ok good. It was just bugging me because my old Civic and a few other cars I've driven all hover around 1/5 or 1/4 up the scale, not halfway so I was just concerned.
Better than mine. :P
I'm assuming my high idle is a combination of a bad TPS and a bunch of cracked 21 year old vacuum hoses in my engine bay.
Old 01-03-2013, 12:31 PM
Better to ask than to just assume it's ok. Also important to know is that it takes a relatively large change in temperature to move the gauge from that spot. That means even a little bit above where it normally is means a lot more heat.
Old 01-03-2013, 01:22 PM
EdWindows's Avatar
Noted. That would explain why it doesn't move whenever I drive spirited with WOT.
