AMR Aluminum Radiator
I suppose that, if someone has one of these they want to sell, they'd already have put it up for sale. Just in case, though:
WANTED: AMR ALUMINUM RADIATOR FOR SVX. In good shape, of course. |
Re: AMR Aluminum Radiator
You mean PWR?
Yeah, thanks.
![]() AMR is coilovers. Last edited by WYOSVX; 11-19-2012 at 12:27 PM. |
Any idea how long it takes to remove old and install new radiator? 1-2 hours? Thanks...doing it tonight. Just wondering how much time is needed.
1994 SVX L FWD "The Blue Bullet" |
Depends on how fast you work and how prepared you are, but 2 hours is pretty reasonable. Are you doing a PWR or a regular radiator?
bought off ebay...china made but had a silla name on it. not in front of me right now. I'm letting a friend do it as he has a garage/lift and I do not want to deal with fluids and cold weather...was wondering about appropriate labor charge to give him.
All aluminum? Similar to stock or better?
The Silla ones are similar to stock, and can be found on ebay for (IMO) a very reasonable price.
Supposedly OEM...Looks just like the original. was advertised on ebay with the factory part number so I figured I'd give a try. Others here have also bought from same seller...radsus. From approx $120 - $150. supposedly higher priced have aluminum tanks. As long as it doesn't leak I'll be happy enough. so...two hours labor...$150?
Make sure that you use only Subaru radiator hoses.
They fit correctly.
@Nate Yea I was wondering about that. WYOSVX, didn't mean to hi-jack your post. I'll see if the replacement fits/works by week end.
