Old 11-04-2012, 01:14 PM
Stayed up until [7]AM last night going through wiring diagrams, pinouts, and the actual wires of my spare engine and body harnesses getting the megasquirt wiring figured out. Pleased to say that I have it about 95% figured out. All that's left to figure out is:
1: whether the crank and cam sensors need any resistors to get a good enough signal to the megasquirt, and there's no real way to make sure of that without actual experimentation.
and 2: how to wire up the IRIS solenoid, which I will probably leave until later because it's not needed to just get the car running. The stock ECU has a constant, switched +12V going to one pin on the solenoid, and grounds the other at the ECU to switch it on (closes the IRIS valve) above 2200 and below 4000 RPMs. The megasquirt has many spare outputs that I can use for this, but I am slightly confused about whether some of them provide ground or power (and if so, whether they are +12V or +5V), and a lot of them are PWM, which I'm not sure whether it would be appropriate to use to drive the solenoid. Probably need to post up on the MS forums for an answer to that one.
I will start actually wiring it up tonight, and post my wiring diagrams and such very clearly and with plenty of explanation soon, once I have verified that it (at least mostly) makes real-world sense.
Very satisfied and proud of myself.
Old 11-05-2012, 02:19 PM
Put my winter tires and rims on .. I now have 16" 17" and 18 tire sets .
[IMG][/IMG]
Old 11-05-2012, 03:56 PM
They look pretty good. I like them.
[IMG][/IMG]
Old 11-05-2012, 07:19 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Installed my new coil pack. Car actually runs halfway decent again, but I still have a loping idle. I'll have to try to track that down sometime...
Also, busted an old brittle vac line while I was at it. Thankfully I had some the same size on the shelf
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 11-06-2012, 12:57 AM
EdWindows's Avatar
5spd + coilovers = win :D
I changed my PCV valve today. Took 2 hours and a lot of f**king swearing, especially when the crow's foot fell off the extension 3 times and I'd use a coat hanger to fish it out from under the intake manifold...
Also broke off a chunk of the dried hose to the point there's a vacuum leak, so I'll be getting new vacuum hoses for the whole engine sometime later this week, and my new coil should be arriving in the mail soon.
Old 11-07-2012, 12:13 AM
Turbone Turbone is offline
Banned
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
After driving mine for 2 days straight I discovered the crank pulley is about t separate
Old 11-07-2012, 12:57 AM
bishop bishop is offline
tried to do mine today and needed a boxed in crows foot, the vac line definitely needs to be replaced.
Upgrade to a light weight 1 peice pulley
from what i've read this could also be the iacv.
Old 11-07-2012, 01:38 AM
EdWindows's Avatar
It's a million times easier if you take the hose off before you wrench the pcv valve, otherwise you have almost no working room to get the crow's foot onto the valve and end up having a bad time.
As long as you don't have giant hands or forearms, you should be able to reach under the rear driver's side of the manifold and pull off the hose from the valve.
Old 11-07-2012, 02:29 AM
those hose came off but it was pretty close to ruined XD
Old 11-07-2012, 04:02 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You can make your own tool for easier removal
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 11-07-2012, 04:55 PM
davew833 davew833 is offline
Dannmarr, what size wrench is that?
davew833@yahoo.com
Former 6-time SVX owner
Old 11-07-2012, 06:44 PM
Wrench size and aprox angles ?
Old 11-07-2012, 07:11 PM
Old Davy's Avatar
Old Davy Old Davy is offline
A tale of botched service with a happy ending, worth the telling:
10 days ago I put the winter wheels on the Outback, having purchased new rubber for the fugly Outback OEM rims at the local 'all purpose' Auto & Hardware chain two years ago. You'd think I would have absorbed the teaching moment that experience was. They 'forgot' to balance them as paid for and I can tell you it was an unsettling and hairy test drive! In the end they were balanced no cost and all is well two winters on.
Chapter 2:
The SVX came with two sets of alloys shod in appropriate rubber, balanced and ready to go...or so I assumed. So, last weekend I took the SVX winters to the same chain (Canadian Tire), simply to have the balance checked. Paid & picked them up, assured that they were balanced, only to have 3 of the new sticky weights fall off in the trunk. After some terse conversations in the office the next morning I determined that the wheels were not pre-checked for balance and the kid simply stripped off the old sticky weights (which were firmly attached), put them on his machine and stuck new weights (the exact same size, number and location) on top of the old rough foam adhesive patches, with black greasy fingers. How stupid do they think customers are? I had spent an hour the night before cleaning old previous adhesive patches off the freshly washed wheels leaving only the old solid weights in place. This should have been my clue that these wheels were not as new as they seemed.
Yeah, I know, your jaw is dropping at this incompetence.
The Shop Manager's lame explanation was that they were too busy at this time of year to take the time to clean off old adhesive. If I brought them back in this Friday - after I cleaned off the adhesive - they would re-balance them as a free repair. I shudder to think how many wheels done that weekend will throw weights come this winter...
Recalling two years before and examining my options I brought the wheels home, stripped off the 24 new sticky weights and again used Ronsonal lighter fluid to completely clean off the adhesive. During this chore my brain decided to start working again.
This morning I visited 3 actual Tire/Wheel/Alignment shops in town to research alternatives. At the third stop, the CAA garage, I was impressed with the cleanliness of the shop floor and no-nonsense, no BS explanation of how they would re-balance the wheels for pick-up at 2 PM. Normally I have my wheels swapped over at Jiffy Lube as well as all fluid changes, which they have done on my Subarus for over 15 years now. Jiffy Lube doesn't do balancing, just rim-mounted tire changeovers. I do believe in shop loyalty.
The CAA offer to computer balance my wheels was too good to pass up so in they went at 10:30 AM.
Phone call at noon. "Dave, we've balanced two of the wheels but the other two are bent out of plane, one by 1/8" and the other by 1/4". Probably from curb impact. Besides which the rubber on these tires have a date code for 2001 - 11 years old...and they are NOT ice or snowtires."
Oh crap. Well, I suppose I could just buy new winter rubber and have them put on the 17" summer alloys, which are graphite black. I was looking forward to lightening up the batmobile appearance of the car with the silver alloys.
What to do? I drove the SVX out to the CAA shop so he could see what the summers looked like and see if they had the correct winter rubbers in stock...or order them in. Fortunately the summers have a 2011 date code so that's all good.
Well, he, George, had a pleasant surprise for me. Yes, he had Firestone Winterforce rubber in stock for 16" and 17". My engineer's eye definitely approved of the tractor tread on the Winterforce 205/55/16 @$127 each. What's the point of Snow Tires if not to be able to confidently claw through deep snow, slush and ice?
George then proudly brought out another option...
A brand new un-boxed set of 16" silver FastWheels 7-spoke 'Salsa' alloys for my consideration @ $104 each. Did they spin my crank?
No-brainer. What I wanted in the first place, a dedicated wheel set for winter, in silver no less. Good looking without all that riceboy advertising cast on the spokes.
Trigger pulled, the whole operation took about 40 minutes while I waited. I was out the door at 3:05 for a quick test drive on the sideroads. Not anywhere as noisy as I expected, in fact no louder than the summer rubber.
All in, including tax, the bill for new alloys, new rubber, balancing and install came to $1100, which seems reasonable to me for winter snowshoes I can trust whatever the weather throws my way. Saved me the hassle & delay of driving all over Southern Ontario sourcing new alloys before the snow arrives.
Oh yeah, George checked the balance on the summer 17"s and they are fine. Plus a $50 rebate from Firestone for 4 new tires...
While up on the hoist I was able to examine & wiggle the underside bits and it sure looks like my exhaust piping back to the rear cat is shiny and new under the shields, making it likely I can get the old mismatched O2 sensors off and replace them with the new NGKs I got from Rock Auto. Maybe I'll let George do it for me...he certainly knows how to win new customers.
The SVX returned to my garage, drove back to CAA with the Outback to retrieve the summer wheels. Since the sun finally came out today for a few days and the temps are rising, tomorrow I will tackle the stabilizer 'thingy scratching my window' fix and I'll be all done for some extended road-tripping in the Dreamship.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 11-07-2012, 10:31 PM
Redone my infamous custom air intake.
Old 11-08-2012, 03:54 PM
SVX8588's Avatar
I was thinking it might be the Idle air control, but I haven't had time to research it.
Good luck with the PCV valve. I did mine earlier this year, and I was able to do it with regular tools. I think I used a 3/8 ratchet with a deep socket but I can't remember for sure. I don't recall it being particularly difficult, but then again I had more working room since I had some things out of the engine bay to do the valve cover gaskets.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
