#361
Re: Building a 10,000 rpm NA engine.
#362
#363
Kind of disagree about the spring load as I see it, it is significant on a SVX other wises the valve doesn't close.
#364
Have pulled the intake manifold off and installed the new top pipe thermostate housing on to the motor and now putting it all back together. On my last trip to the desert I stuck a hole in the condensor for the AC so I have pulled it out short term and I will run some tests on airflow throught the radiator with and with out the unit in place. I personally feel the SVX unit blocks the airflow to the radiator to much.
The current thermstate that is in the top housing is a 61C (140F) the aim here is to find out if we can keep the engine temp down around 71 - 77C which is in line with what they do on the V8 super cars in Australia. Seem to remember that the Nissan GTR that I was in a couple of years back had a engine temp of 65C. Will post photos and performance details as it becomes avialable. Tony
#365
Okay,
New thermostat housing fitted and job completed see attached photo. The way the final install work out was far better then I expected. Testing to start now. Tony
#366
Well fired it up and what do you know the engine boiled but the radiator was stone cold. Head guages showed 110C and the radiator 40C it occured exactly like Bazza suggested and that is with still having the two smaller bypass pipes connected. I know what the problem is so I will fix it in the morning and run the next trial.
Tony
#367
(bonus points if you can make the t-stat close the bypass as it opens) I am at work, but if I can get a chance I will draw up a diagram in mspaint.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 10-04-2012 at 09:03 AM. |
#368
Very clean! You wouldn't even know it's there unless someone pointed it out to you. Think you could take a pic or two of the bottom rad hose and how it attaches to the modified thermostat cover and modified lower radiator outlet? Thanks. Bill
#369
The solution to my issue is that I just need to drill a hole in the side of the thermostat, about 3 mm and that will be enough to open the thermostate. I will get that done and come back to you in the next hour.. Will also get the photo Bill. Tony
#370
Mmight want to look into a failsafe stat like the one i used in dans car
Tom |
#371
#372
Thanks for the info. I didn't realize that Chevy thermostats were the same size as ours. Bill
#373
Problem solved drilled a 4 mm hole in the thermostate and the problem has gone away. Opens correctly and due to the low temp state 61C the engine sits around 65c to 75 C. The day is due to be hotter around 34c so I will report back tonight on how the new set up behaves.
Tom that is a good idea would still need to drill it as the coolant does not get to the stat get it to open in the start. I think its smart the way it locks open. One benfit of this new approach is the fan are never on other then when the AC is on. Bill photos attached. Tony
#374
Bill... its not... i used ut in their stat housing... which is why i recomend them. Tony.... it works just fine... you could say "trust me" Tom |
#375
Thanks for the clarification!! B
