View Poll Results: When did your water pump fail or leaked, or was replaced before failure or leak
Leaked or failed less than 65,000 miles 0 0%
Leaked or failed 65,001- 100,000 miles 6 16.22%
Leaked or failed 100,001- 130,000 miles 8 21.62%
Leaked or failed more than 130,000 miles 2 5.41%
Replaced (no failure or leak) less than 65,000 miles 1 2.70%
Replaced (no failure or leak) 65,001- 100,000 miles 1 2.70%
Replaced (no failure or leak) 100,001- 130,000 miles 13 35.14%
Replaced (no failure or leak) more than 130,000 miles 6 16.22%
Voters: 37. You may not vote on this poll
Old 10-08-2004, 07:12 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Re: cool
Originally posted by SSSVX
Look like we got a really good water pump......
My original one still runs great at 67k in a 12yrs old machine.
Hope to have many, many miles to go...
After reading Beav's post, when, when and when should I change mine? Does it have any warning before it happens? Leaking is better than seizing! Maybe I should put some 'lubricant' for the pump........
Nope, any attempt at lubricating, other than keeping good, clean antifreeze in the system, would not be a good thing. I'd just recommend replacing it at the same time as the t-belt, which in my book of humble opinions, should happen around 90k-100k miles.
Old 10-10-2004, 04:27 AM
oab_au oab_au is offline
I'm not sure,,,,,,,,,,,
But, I thought I saw a Beav.
One Arm Bloke.
Tell it like it is!
Old 09-20-2012, 10:06 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: Water Pump
HA! I was thinking of starting a water pump poll and then I found this dinosaur poll. I think this is interesting. Vote in this if you didn't do so EIGHT YEARS ago! It looks like only 12% of pumps fail in less than 100K miles. And, of those, one guy lives in a particularly severe environment and who knows if the others had a tendency to either rev up their cars or not replace the coolant regularly.
Tony
Old 09-20-2012, 10:51 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Water Pump
my 97 ebony is at OT's as we speak getting an engine reseal, and still has the original water pump with 160k and no leak
1995 POLO LSI 76K MILES SOLD
Old 09-20-2012, 11:06 AM
Re: Water Pump
Just wondering, who selected failed between 65k and 100k just now?
Tony
Old 09-20-2012, 11:09 AM
Re: Water Pump
That would be me
Are you stalking me?
Old 09-20-2012, 11:18 AM
Re: Water Pump
That would be me
Yes. Did I read your post in the other thread correctly that this car had been sitting for 4+ years? Was the pump dead back then or could it have seized up while sitting? Actually, I would be surprised if a pump that old didn't seize up after sitting for 4 years!
I wouldn't let one of my cars sit for more than a week. I did that ONCE and bees built a nest near the door latch that I discovered when I opened the door!
Tony
Old 09-20-2012, 11:22 AM
Re: Water Pump
The car was parked when the pump went.(was originally thought the cam sensor went) Also, them sitting for years has no affect. Trust me, the other one I picked up had been sitting just as long and fired right up when I put in a cam sensor that it needed. Also, I've bought quite a few other SVXes that had sat for anywhere from 2-5 years before my purchase and they fire right up and have no pump or belt issues of any sort.
Old 09-20-2012, 11:58 AM
Re: Water Pump
I'm curious how you know for sure the water pump has never been changed. I only bring this up because unless you have all paperwork for any service, or asked the owners directly or have owned it since new(even this isn't always reliable as many people have no idea what's been replaced on their own cars), there is no way of knowing.
Old 09-20-2012, 03:06 PM
SVX92-97's Avatar
Re: Water Pump
Nate, I bought the car last year from a seller who bought it in 2001 with 60k miles on it from a dealer, and he never replaced the pump, and I would highly doubt a dealer would replace a water pump on a 60k mile car if it wasnt leaking. So IM 99.9% sure its still the original pump.
Old 09-20-2012, 08:55 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Water Pump
I never replaced mine and I'm up over 200K! I drive it on weekends only.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 09-20-2012, 09:00 PM
Re: Water Pump
I didn't replace mine when I did the T-Belt around 120K and it started to leak maybe 5000 miles later, so I got to do the job all over again.
Old 09-20-2012, 09:32 PM
Re: Water Pump
Ok, who was person #5 that had one fail before 100k miles?
Tony
Old 08-29-2013, 01:50 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Water Pump
Just crossed the 100K mark, by a couple miles. It's starting to leak. Wondered what would go first. I have had the replacement timing belt for about 4 years now. For the water pump, is Subaru OEM the best route to go?
Gene
Gene and Ben
Old 08-29-2013, 03:06 PM
Re: Water Pump
Gene
YT only likes Subaru water pumps, I go with the $52.00 remans and have not had one fail yet,
9 second Sunbird?!?!
1/8 or 1/4?
