Old 05-27-2012, 06:39 AM
immortal_suby's Avatar
Thread Killah
Wow - so that's what a rusted mount looks like!
Locker Link
2015 BRZ Limited 6MT
Old 05-27-2012, 07:38 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Both struts are blown, the one mounts got a hole in it, and the other just collapsed itself the whole way around. Maybe that's why it wouldn't line up for the previous owner.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-28-2012, 07:13 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Drove out to Palm Dessert and met with David (dromano) for lunch.
It was a good time. We had good food, good conversation, and took some photos of our SVXs together.
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 05-28-2012, 07:38 PM
Your cars look great!
Old 05-29-2012, 04:41 PM
svxwill's Avatar
svxwill svxwill is offline
New for 92 SVX in 2012:
Valve cover gasket seal kit (L/R), Cam seal (L/R), Timing Belt/Gears, Water pump, Thermostat, Ignition Coils (6), NGK IR spark plugs, Front sway bar bushing, AC holes, Trans cooler
:1992 Pearl LS-L :182,000 (5/2010) – 210,000 (1/2013)
:MOD :Raybestio STS front rotors :Green air filter :Aero resonator :Magnafow muffler/dual tips :RE970 tires
DONATED :92 Claret SVX OTHER :07 Scion tC (wife) RIP :94 Blk Mustang GT :89 Slv 240SX
Old 05-31-2012, 08:26 AM
Old Fogey
Spent a good part of Wednesday rebuilding the knuckle in the Legacy shift linkage. The original bushings were literally "gone", allowing the shifter to wobble around, actually moving as much as 6" to either side, while in gear. Very distracting having it move of its own accord every time it took a corner. Also replaced the nylon ball on shifter end, worn quite a bit as well, after 236K miles. Hardest part of the exercise was driving out the roll pin that held the whole thing together, above the driveline and exhaust. Did I mention it was 95 degrees in the shade yesterday?
Glenn
Old 06-01-2012, 11:53 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I just finished replacing the spark plugs. Thank God for the hole in the wheel well! I couldn't find my spark plug sockets, so I used a standard socket set. After all was done, My wife found my spark plug socket set in the dining room! Don't ask
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-01-2012, 12:06 PM
Onor's Avatar
Onor Onor is offline
Finally got the new brake lines onto the front of my car (thanks for the picture, Dannmarr!). Now I just have to tackle the back....
Need more PB Blaster!
But on the bright side, she's not loosing brake fluid anymore! I shocked a friend with how quick the SVX stops when we tested them last night.
~TEck
Old 06-01-2012, 12:33 PM
~TEck
Tim....I still haven't gotten those pics to you....
Old 06-01-2012, 01:11 PM
Onor's Avatar
Haha! No Worries Huck, I haven't taken the videos you took while I was driving off my phone either. We'll get them swapped sooner or later.
Maybe you can save them as a reason to come back up this way (or Back to Reading!!)
~TEck
Old 06-02-2012, 03:08 AM
kwren's Avatar
kwren kwren is offline
Sounds like my house!
Keith
Old 06-02-2012, 07:17 AM
Thats where I keep mine,
you know,
on the table,
beside a transmission.
Old 06-09-2012, 11:27 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
finally got around to replacing one of my front struts (going to do the other tomorrow the car is so much better to drive now...no bouncing not as much lean and no more rattling the strut was useless no resistance left at all...you could hold one end of it and swing it like one of those light sabers and it would fully extend oh and i replaced the upper mount which wasn't even attached anymore
gotta love these cars
Jared
1992 dark teal SVX LS
Old 06-09-2012, 12:42 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
replaced the sway bar bushings, after they were destroyed in several hours of them twisties.
it wasn't hard but boy that underside is oily
message me if you know a cheap and not-so-hard way of cleaning it
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 06-09-2012, 12:59 PM
Not today but 2 days ago tightened up all the spark plugs , recharged the AC still leaking, ordered all new 0 rings from Subaru. Surprised less than $2 each.
