Old 03-18-2012, 07:17 AM
Originally Posted by fzftw View Post
Looks great!
Thanks! Whenever I change them over I am always surprised at how much more eye catching they are than the visually neutral stock wheels. Like them or hate them they draw attention.
Old 03-18-2012, 08:11 AM
stickyfinguhz stickyfinguhz is offline
sean your rims look sick! they would look good with my all black i think
Old 03-18-2012, 10:24 AM
fzftw's Avatar
fzftw fzftw is offline
Just dip a toe!
Visually neutral is right. I hope to get my new wheels on soon.
-Brian
Current fleet:
89 D21 2wd
91 XT6
93 D21 4wd
95 SVX LSi
02 Windstar Sport
03 CL500
03 Avalanche NF
07 RDX
08 Outback
10 Outback
10 Murano
12 Accent
15 STi
Old 03-18-2012, 11:22 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Mr. Nossida,
Muffler shop charged me $60.00 to replace the resonator with a generic in-line design.
Gene
Gene and Ben
Old 03-18-2012, 03:26 PM
92 SVX 92 SVX is offline
Washed it today, after I got back from the beach. it was a good day though I am as red as a lobster lol
Old 03-18-2012, 08:08 PM
I was too cheap to buy a new one, i just went without it.
Originally Posted by Mr. Nosidda View Post
Also, how much was it to do this?
$32 total at a Monro muffler chain store in CT.
Here is my thread on it:
http://www.subaru-svx.net/forum/showthread.php?t=54792
Old 03-18-2012, 11:20 PM
Mr. Nosidda Mr. Nosidda is offline
Originally Posted by bwb3 View Post
Mr. Nossida,
Gene
Thank you,
today i put LED's into the lights above the license plate frame.
Old 03-20-2012, 01:24 AM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Another K on the clock!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 03-20-2012, 08:39 PM
Rod.'s Avatar
Rod. Rod. is offline
538 km added today to the 450 km on the weekend is about 600 miles of more, trouble-free, driving!
That's about 178,800 km in total (or just over 111,000 miles), and almost 4,500 miles on the rebuild.
(Typical Canuck mixing miles and kilometres... :-)
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 03-20-2012, 10:53 PM
I picked some pebbles off the roof and stuff. :|
Old 03-21-2012, 11:49 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
My 92 with 122k miles on board i had the following items replaced, there shouldn't be a leak seen anywhere:
Six NGK iridium spark plugs
Gates timing belt & PCI timing roller set
Water pump
Subaru upper & lower radiator hoses
Four radiator hose clamps
Subaru thermostat
Subaru thermostat gasket
Subaru WP bypass hoses
One WP bypass hose clamp
Two Subaru intake cam plugs
Two Subaru exhaust cam seals
Subaru front main seal
Subaru oil pump O-ring
Two new flange bolts for the thermostat cover
Subaru valve cover gaskets
Twenty Subaru VC washers
Subaru PS reservoir O-ring
Exhaust ground strap & SS washer
Subaru hi pressure PS hose
Factory brackets for new style PS hose
Vacuum line for fuel pressure regulator
Thanks goes out to OT
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 03-21-2012, 12:11 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
rotated the tires so that they all face the right way again by myself on a hill which was fun changed the oil and found out the my "oil pressure sending unit" is leaking so that needs to be replaced.
Jared
1992 dark teal SVX LS
Old 03-21-2012, 12:26 PM
Thanks, Henry!
Make sure that you only use a factory Subaru 25240KA040.
Old 03-21-2012, 12:50 PM
redlightningsvx's Avatar
Collision Refinishing Tech
What's wrong with the aftermarket ones OT cause I need to replace them in both cars soon?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-21-2012, 01:20 PM
Thanks, Henry!
Yeah the one in there isnt a subaru part which Is' why its leaking I have a feelin
Jared
