Old 03-05-2012, 02:32 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Help, No Power! (power mode, that is)
Well, I finally got around to removing the remote car starter (that I thought was an alarm) that I mentioned in the Power Mode Selection thread, and it didn't make a difference.
Here the summary of what's not working:
1: The gear indicator lights in dash don't light up. All bulbs except "D" are good.
2: Power light / mode. I'm sure the bulb is good, but it doesn't even come on momentarily when I start the car. I have never seen the bulb light up, and have not noticed any significant change in shifting when I "mash the gas"
3: Manual light / mode. I have played with the manual button and shift lever several times and it doesn't seem to make any difference no matter what combination I try. I know the bulb is good.
4: a few other random illumination bulbs (defroster, cruise, etc). I think these are just blown bulbs, but I figured I would note it anyway.
5: the air bag light is on.
6: the security system. the light comes on when I push the button but I can't get it into programming mode so I'm not sure if my keyfob works. I don't think the electric locks work either. I haven't thoroughly tested this since removing the remote starter.
Most everything else electrical seems to work.
While I had everything apart to remove the remote starter, I swapped the door lock timer and the Time Control Unit from my parts car to see if that made any difference, but it didn't.
I do notice now that there is a relay clicking behind the glove box when I move the driver lock, but the passenger one doesn't move.
Any ideas? I'd really like to get power mode working, and it would be nice to get the other issues straightened out.
Thanks!
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-05-2012, 02:46 PM
Re: Help, No Power! (power mode, that is)
I'd bet the gauge cluster is not making a good connection to the harness on the back of it. Either that or the wiring from the TCU to the harness that eventually leads to the gauge cluster.
Power mode will work whether the light lights up or not. My '97 doesn't have a power light on the cluster at all and the switch still makes power mode work like normal.
Old 03-05-2012, 03:26 PM
oab_au oab_au is online now
Thanks!
All these lights and their functions.
1.The gear indicator lights.
2. Power light / mode.
3.Manual light / mode.
Have to work for their functions to work.
First put the FWD fuse in to see if the FWD light comes on. If it doesn't check fuse No. 15 in the under dash box. If the FWD light does come on, then it is the Dimmer Control that is the problem.
One Arm Bloke.
Tell it like it is!
Old 03-05-2012, 06:41 PM
SVX8588's Avatar
The FWD light does come on when I put in the fuse. I did a quick search on the Dimmer control, but I'm not entirely sure what / where it is. I noticed several black boxes under the dashboard when removing the remote starter. Is it one of those?
Thanks!
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-05-2012, 08:16 PM
Thanks!
I don't know mate, it looks like it is in the Dash somewhere. It shows up in the Diagrams, included in the Combination meter, Instrument panel.
One Arm Bloke.
Tell it like it is!
Old 03-05-2012, 08:47 PM
SVX8588's Avatar
What diagrams are you using?
I can't seem to find any comprehensive ones...
Thanks
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-05-2012, 08:49 PM
Thanks
Work Shop Manual book 6, Electrical.
One Arm Bloke.
Tell it like it is!
Old 03-05-2012, 08:52 PM
SVX8588's Avatar
Any chance there's a digital version of that on the site somewhere?
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-06-2012, 04:22 PM
Tracing out the plugs and wiring, it does look like the Dimmer Circuit is probably just an IC on the dashboard. It is fed by the center plug that plugs into the dash.
One Arm Bloke.
Tell it like it is!
Old 03-06-2012, 08:20 PM
SVX8588's Avatar
Great! I will check that when I get a chance.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-07-2012, 12:37 PM
SVX8588's Avatar
Well, I found the dimmer control. This is what it looks like:
And this is why it didn't work:
So I soldered the broken path back together and put it back in and now it's blowing the Meter/SRS light fuse as soon as I turn the key.
I guess there must be a short somewhere in the dimmer control circuit, so I am working on testing the transistors on the board to see if any of them are bad.
Or maybe someone has one of these dimmer control boards that they want to sell cheap
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-07-2012, 12:45 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: Help, No Power! (power mode, that is)
This may help you - some info on the IC
C1251C is Dual low power Op AMP
Pin 1 Output A
Pin 2 Inverting Input A
Pin 3 Non-Inv Input A
Pin 4 GND
Pin 5 Non-Inv Input B
Pin6 Inverting Input B
Pin7 Output B
Pin8 V+
Could use uPC1251 from "www.necel.com"
if you take photo of rear - then I could get you a nice schematic - as PDF (unless you already have one ?).
I am a PCB Designer ..... have been for past 30 years.
Old 03-07-2012, 01:24 PM
SVX8588's Avatar
Thanks! I don't know much about ICs. Do you think that might be the problem? I'm not even sure how to test it...
I don't have a schematic. Here are two pics of the back side of the board. Sorry they came out kinda dark.
I did test the big transistor and it seems to be good. At least, it's not shorted.
Thanks a lot for your help!
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-07-2012, 04:09 PM
SURTEESS's Avatar
I'll get on to it this weekend
In the mean time here is the pcb mirrored - so it lines up with the component overlay.
Old 03-07-2012, 04:21 PM
SVX8588's Avatar
Ok, thanks. I may start pulling out components and testing them, but it seems like the resistors and capacitors would show some outward sign if they were bad.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
