Old 03-01-2012, 09:03 PM
Will Will is offline
Wheel bearing press out
What is the best method of getting bearings out of hub assembly? I tried to press them out with a 12 ton machine at a friends house and they didn't budge... At all! I even fabricated a piece of aluminum on a lathe so that only the outer race of the bearing would be in contact when pressing. Needless to say I couldn't believe this didn't work. What am I doing wrong?
Old 03-01-2012, 09:17 PM
Re: Wheel bearing press out
"Did you remove the hub first?
Did you remove the snap ring?"
Old 03-01-2012, 09:29 PM
The illustration I went by had me under the impression that the hub would just fall off when pressing the bearing.
There was no snap ring once I got in there nor any trace of one ever being there.
Old 03-01-2012, 09:36 PM
You have to remove the hub,
remove the outer seal,
and then remove the snap ring,
before you can press out the bearing.
Old 03-01-2012, 10:15 PM
I, for one, was unable to get one of the bearings out of my blue car with a hub tamer. If I had tried any harder I would have probably destroyed the hub tamer.
I will look and see if I have pics of the process so you can see the snap ring Tom is talking about. For now (when it's all still on the car), it is toward the outside of the bearing (meaning that if it's the left bearing, it's to the left of the bearing), inside the cylinder thingy (unsure of proper terminology) that the bearing is pressed into, and you should be able to get it out with a pair of pliers. When you press the bearing out, the bearing should be moving toward the outside relative to the car as well.
Old 03-01-2012, 10:18 PM
http://www.subaru-svx.net/photos/files/SVX10/35448.doc
These were the Schematics I was going by which neglected detail on removing the hub. So How is that done? Sorry if it's a stupid question.
Old 03-01-2012, 10:37 PM
Number 22 on page 6 is the snap ring. Make sure to remove that. For the hub, just gently tap it out from the other side with a mallet or something. Mine was kind of stubborn so I put a pipe against it on the inside, and hit the end of the pipe with a hammer until it steadily popped out. The "bearing separator" on page 7 will definitely come in handy.
The E-brake is an absolute ***** to put back together, make sure to have at least 1 extra pair of hands to help you out. In the dark, with a buddy who also does not know what he's doing and a crappy flashlight, it was not enjoyable.
That is a damn thorough guide, I will be saving it for my records.
Old 03-01-2012, 10:54 PM
[QUOTE=icingdeath88;698418]Number 22 on page 6 is the snap ring. Make sure to remove that. For the hub, just gently tap it out from the other side with a mallet or something. Mine was kind of stubborn so I put a pipe against it on the inside, and hit the end of the pipe with a hammer until it steadily popped out. The "bearing separator" on page 7 will definitely come in handy.
Ok, I will try this out first thing in the a.m.
yea I kind of imagined it would be. I took picks and kept it consolidated disassembled, and will for sure have a hand. Can't imagine doing that in the dark! (bows)
Old 03-01-2012, 11:00 PM
Much appreciated!
Old 03-01-2012, 11:16 PM
Originally Posted by Will View Post
Much appreciated!
That is what we are all here for.
Old 03-02-2012, 03:17 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Check my locker for detailed pics
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 03-02-2012, 07:31 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
I found it enjoyable!
At least we know how to do it..lol
Old 03-06-2012, 02:09 PM
I'm at a stand still. I can't press this bearing out because of the knuckle lip. What to do?
Old 03-06-2012, 02:18 PM
You're supposed to press it out in the other direction, after the snap ring is removed. Flip it over and look at the other side.
Old 03-06-2012, 02:23 PM
it looks to me like you separated the inner and outer bearings and that lip is part of the outer race. you should be able to push the entire housing out. bearing assemblies are generally two separate bearings in one housing, an inner bearing and an outer bearing. i may be looking at the picture wrong but it looks like that lip is the divide between the two bearings and not part of the knuckle.
