Best source for new front wheel bearings.
hey all, i found them on subaru parts and rock auto, is there any other good places to order a set from/
should i replace my shock mounts while im in there? whats the best to use there? also, anyone got a used hub, if my right fronts cooked? Last edited by Jay Wrix; 01-22-2012 at 11:58 AM. |
Re: Best source for new front wheel bearings.
I'd go with best price on the bearings. Quality of the install probably matters much more than make of the goods.
Strut mounts will have to come from Subaru, I believe. dcb |
Timken for wheel bearings are pretty good quality. I have them installed on my 1995 SVX and no problems/issues whatsoever.
Jackie from Annapolis Subaru will give you a really good deal on genuine Subaru bearings.
![]() jackie.whetzler@annapolissubaru.com
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
ended up getting a moog bearing, and seals for both sides, the two serph belts, for $95 shipped.
came to my door two days later. A+ in my books. |
everything cam apart, minus the snapped in half abs sensor.
boo! finally and excuse to not use my abs for a while. |
