Old 11-09-2011, 05:52 PM
simboglide's Avatar
simboglide simboglide is offline
upper cam rubber seal rubber plugs
Do these pop off??i can get a screwdriver between the plug and the head but looks like they'll tear if i pry them away.
Old 11-09-2011, 06:18 PM
Re: upper cam rubber seal rubber plugs
There's metal inside them, so it has enough structure to come out in one piece. Don't plan on reusing them though.
I usually put a flat head screwdriver against the side of it and give it a few solid taps with a hefty hammer. Pops them out pretty quick.
Old 11-09-2011, 06:37 PM
simboglide's Avatar
Are there no seals for the upper cams?popped the cap off...no seal
Old 11-09-2011, 06:44 PM
the intake cams use "plugs" as seals, so yeah just the black plugs, replace those and your good to go!
Old 11-09-2011, 06:46 PM
simboglide's Avatar
kewl...thxxx
Old 11-19-2011, 01:55 PM
simboglide's Avatar
engine is back together,,i hate to dry start it since oil pump was off.. fuse i can pull so it'll pull oil around w/o starting?
Old 11-19-2011, 02:08 PM
I can't think of anything easy to pull that would let you do that. You can jumper the starter solenoid to get the starter to turn though. That would do it.
Old 11-19-2011, 02:11 PM
simboglide's Avatar
maybeee..i can just bump it around a bit...
Old 11-19-2011, 03:28 PM
Cam Cam is offline
You could just unplug the 6 injectors and crank the engine a bit. The only problem doing it this way is that you are moving the internals while priming. It's not the best method, but I did it a similar way and did not have any issues.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 11-20-2011, 11:34 PM
svxpert svxpert is offline
<<You could just unplug the 6 injectors and crank the engine a bit. The only problem doing it this way is that you are moving the internals while priming. It's not the best method, but I did it a similar way and did not have any issues.>>
i dont know of any other way to get oil around the engine without moving the oil pump huh? pull the ignitor plug and save yourself from pulling an extra 5 wires. or if you can fit your hand down there, pull the cranks sensor plug.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
