no power
the other day I went to start my car and it was dead It wouldnt take a jump. I got the alt tested it was fine It had a battery that was only 3 months old but it tested bad. So I installed the new battery and still nothing what could it be.
Re: no power
Do you hear any clicking noises or signs of life from the starter? When the key is turned on does the dash light up? Do the electrical systems in the car work?
Re: no power
absolutly nothing no dome light when the door is open no radio and clicking.
Re: no power
i meant no clicking theres no power to anything.
Re: no power
Check your fusible link.
Re: no power
im not sure what that is can i get a little more detail for an electrical dummy.
Re: no power
fuseable link is in the fusebox under the hood, just look at the diagram on the box top, make sure your cables are clean and tight, from what you've said there should be no problem with the fuseable link just a bad connection, keep us posted on progress.....................G
I thimk ther4 I an, what? huh! ![]() 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 ![]() 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
10 points to nate bad fuseible link. I happend to have an extra from a parts car i had. also was wondering if that could be a sign of other problems? thanks alot
Re: no power
Re: no power
*Shakes fist* That's where I was going with this!
Re: no power
O boy, why o why did that link blow, maybe just old and tired like me.........G
