Old 08-29-2011, 01:21 PM
Ironhydroxide's Avatar
Ironhydroxide Ironhydroxide is offline
SVXT6 Project
Transmission options
Hey, I recently acquired an '95 SVX with a grenaded front diff.
I'm wanting to stay Autotragic (lazy car)
what are the best options for transmissions? reasoning?
(yes I know I'll have to swap rear diffs to match transmission, and yes I know there could be various problems with CV Axle spline count/diameter, thus the question)
My main goal for this car is to have a lazy cruiser. Something that looks good, gets OK gas mileage, and is comfortable to drive in town, as well as cross country if i so desire.
I have heard good things about the 4.44 from the outback. but what is cruise RPM on them? detriments?
would going 3.9 instead be good?
or how about just splitting the case, fixing/replacing broken front diff, and r+r the stock trans with external filter and cooler?
Thanks for the input.
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine)
Honda FT500 Ascot [Red]
Old 08-29-2011, 01:35 PM
SVXT6 Project
Re: Transmission options
me=fail
http://www.subaru-svx.net/forum/showthread.php?t=55838
Old 08-29-2011, 02:00 PM
Huskymaniac's Avatar
Uses the ignore feature
I would be as concerned with the 3.9 as I would be with the 4.11. Can a 4.44 or a later year 3.54 from an SVX be modified to be a 3.9? The 4.44 and the later year SVX trannies seem to have better clutch and other parts in them.
Tony
Old 08-29-2011, 02:02 PM
SVXT6 Project
as this is a 95.... would it have the "stronger" transmission? and that said.... it's only the diff thats shot... so. is replacing it fairly easy?
I would prefer to have the Stock gearing... just to be that way. BUT if it'll just go out whenever it damn well pleases... then thats no good.
maybe i'll have to bite the bullet and get these http://www.ecutune.com/4eat.htm
Old 08-29-2011, 02:31 PM
The '95 I would just take the trans to a shop and have them change the front diff. You can change to a different ratio too if you like. The 4.44 one should be a lot stronger due to bigger teeth on the gears and therefore less likely to break and have this happen all over again. And changing the rear is supposed to be pretty easy too.
Old 08-29-2011, 02:51 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Stronger, maybe, if you believe Subaru but when comparing the weakest man in the world to the second weakest man in the world the later may be stronger but he's still a wimp.
Old 08-29-2011, 05:55 PM
SVXT6 Project
I'm not really afraid of splitting transmissions. I've done my fair share (maybe more) of Manual transmissions... Automatic isn't really all that different when you get down to the logic of it. Maybe i'll just do it myself and hope the trans doesn't grenade.....
Old 08-29-2011, 06:28 PM
oab_au oab_au is offline
While you are repairing the front diff, you might fix the AWD.
That is probably why the front diff failed in the first place.
One Arm Bloke.
Tell it like it is!
Old 08-30-2011, 05:21 AM
If you want the 3.90's, get one from an early Legacy Turbo, they have the extra clutches like the SVX tranny....
But that being said, get a 4.44 tranny, you won't regret it once you drive it....
Old 08-30-2011, 06:08 AM
I find it hard to take advice on reliability seriously from someone that drives cars made in England. For reliability I think I would drive a Hyundai before a British car.
Tony
Old 08-30-2011, 10:03 AM
SVXT6 Project
Problem is Huck, I want to have this as mostly a freeway cruiser... and just a lazy town car. Nothing extremely sporty (i have 2 other cars for that).
and I wouldn't mind having the best fuel mileage possible with this lazyness of a drive. so i am leaning towards getting LAN's Transmission, TCU and V1A1 Ecu (or whichever Stage 1 is the most recent)
Thoughts?
Old 08-30-2011, 10:56 AM
Thoughts?
I don't think you can go wrong with LAN's transmission and upgrades. If you've got the money go for it.
Old 08-30-2011, 11:05 AM
Thoughts?
I once heard that, at a given speed, a car will get its best gas mileage if running at the peak of the torque curve. I have never been able to prove it mathematically and I have never seen hard data to back it up but I'll throw that out there. But, if it is true, you would want your typical cruising speed to correspond to the same RPMs as the peak of the torque curve.
Does anyone have the stock engine dyno curves? The closest link I have was with a stock engine running on the stage 1 ECU which may or may not have affected the data.
Tony
Old 08-30-2011, 11:21 AM
SVXT6 Project
Well finding Gear ratio's isn't hard. and calculating ratios and speed isn't hard either... SO. I guess i need that Dyno for the Stage 1.
Old 08-30-2011, 11:29 AM
kwren's Avatar
kwren kwren is offline
Ouch, Benebob! A personal Attack...
Keith
