#31
Re: stumbling idle and backfiring, PLEASE HELP!!!!!
any bad ground can contribute. As Harvey said Quote:
#32
Can someone get me a picture of the ground on the dog bone?
I has teh FWD LS-L |
#33
So I checked the grounds and they're all connected. What next?
#34
how did your plugs look? were any of them different than the rest? this can narrow down your search to specific cylinders or problems. for example plugs with a pinkish color on the electrode means you have too many additives in your gas, yellow too much sulphur, etc...
#35
Now my battery isn't charging, alternator.......
#36
Maybe the battery just took a s*** from sitting for too long unused.
#37
Hopefully, I got it charged at autozone and they said it was good though.
#38
mine is running alot better.
maybe u should try the ethanol free gas in st cloud. that is what i did. that and gonna replace fuel flter. |
#39
I'll be there personally to help you figure it out if you haven't by then in about 2 and a half weeks or so...
#40
Are you referring to me?
#41
The battery was completely done, luckily it was still under warranty. It also cleared up the idle a little, although the improvement is barely noticeable.
#42
of course man. I'll be in Florida and can try and give ya a hand
#43
I seriously recommend to get something like the ECUtuner - you can see most of the critical readings in real time while you drive (have a friend with you to work the lap top).
Takes a lot of the guess work out if you know what's going on. Tapani |
#44
When are you coming?
#45
Also, I unplugged the O2 sensors today and it didn't run any worse or better, nor did it throw a check engine light. WTF?????
