Gauge Cluster swap
Here's the how-to and photos to replace individual gauges in the gauge cluster.
First remove the cluster (that's pretty straight forward) Unclip and remove the clear plastic cover (red arrows show tabs to unclip) pic 1+2 Remove screws in pic 5 and then unclip tabs (pic 3+4) and remove black cover Be mindful of the small filament still holding them together (green arrow) Remove the 4 screws shown in red (speedometer) and the gauge can be pulled out the front of the cluster. This can be done with any of the gauges. There is nothing to unplug as the screws are what conducts the signals to the gauges. Now the gauge out of the cluster. As you can see, this works with any of the gauges:
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
Re: Gauge Cluster swap
Really? I assumed it would be a PITA and have avoided replacing my "D" light. How easy is it?
There is a separate how-to containing instructions on removing the trim around the instrument cluster.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) Last edited by bwb3; 08-24-2011 at 01:54 PM. |
Yeah but you still need to take the cluster out. I found the writeup. Seems like it could take awhile. I'm guessing "D" and "3" are the ones that burn out. If I get brave and decide to give this a shot, I'll PM you about the bulbs.
If u want to remove or cover the PND123 because it is now 12345 <LOL> 5 speed How do u do that?
(top pic) only without taking out the gauge. There is a little clear plastic panel that has the PRND321 printed on it that just pops right off.
im working on making mine purple, i bought led's 9smd bulbs for the rpm and mph clusters.. the problem is 9smd takes too much powwer ffrom the others because they dont all light up when i plug in the cluster. for the fuel and temp gauges i bough led bulbs with just 1smd.
Have you tried taking the speedometer apart further? My speedo is reading slow with an accurate odometer, and I am wondering if the speedo can be repaired.
Bill Z |
I have all white gauges. Did he ( PO) change them? OR did the 1994 come with white faces?
PO changed them. PlanetSVX.com (AKA Dayle, AKA Motorsport Warehouse in AZ) used to (maybe they still do) sell white face gauges. They call them EURO gauges. I think the gauge cluster is still basically the same though.
If it's consistent you could move the needle. If not then make sure the speedometer is screwed in tight (4 screws).
On the warning light bar aross the bottom of the cluster, I noticed there is a green Econ light next to the Power green light. I have never seen this light up on my car. What gives???
Gene
Euro/Aussie/JDM leftovers...
