Security System Problems
So Here's My Problem. The Security Light On The Security Button Behind The Sterring Wheel Is A Constant Red Light. It Does Not Flash. I Have Tried Two Different Security Modules. The One Behind The Glove Box Door But Both Act The Same Way. I Was Hoping Someone From Our Group Might Be Able To Assist With Some Additional Info Regarding A Rest Procedure. I Have Also Checked The 1 Amp Fuse In Both Modules And They Are Good. Tried Unhooking The Battery And Reconnecting But That Hasn't Made A Difference Either. Does Anyone Have Any Suggestions????
Re: Security System Problems
Need Answer Quickly
A solid light indicates a failed security module. Both of your modules are bad. It is becoming very difficult to find functioning modules as it seems disconnecting and reconnecting them can damage them.
Is there a right and wrong way to remove and put them back maybe?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Unhook the battery first....
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
