Re: Sometimes start issue
My NSS is nothing but a control circuit - there is no current flowing through it, (certainly didn't route the 30amps for the starter solenoid through it!) so the gauge of wiring used should be of little to no consequence. Additionally, I did the set-up I did after several "Q&A" sessions with Huck, who is and has been running a similar setup on his 5speed swapped cars for quite a while without issue.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
Find my thread "ecu making noise". There is a schematic for the starting circuit there.
It sure is, and I'd rather be able to find out what the problem is too, but I'm too busy these days to chase down stupid electrical problems.
Is your NSS wired through the harness that used to lead through the automatic? I noticed those wires were pretty thick, which made me think that the current for the starter was supposed to flow through there. I'm going to check over the diagrams as well to see if I can figure it out.
Here's the starter wiring diagram, looks like the current for the starter solenoid does go through the neutral switch.
Excellent, thats what I was looking for. Now I just need a day off and nice weather...
![]() ![]() Does anyone have wiring diagrams showing the schematics for the control wires involved in this circuit - i.e. what parameters need to be satisfied in the security schematic to cause pins 2 and 4 on component B73 to be connected? As well as the inhibitor switch. I'm also going to check the wires for my NSS, I ran them through the firewall and grabbed the wiring harness on the other side. Time to check for some melting... ![]()
Mine are some speaker wire I found, but I pulled the harness inside the car and tucked it behind the A/C stuff. But it seems to me that that crappy, skinny wire isn't letting enough current through to the starter solenoid. What gauge of wire did you use?
Thanks for the help folks - need this snowstorm weather to leave the NorthEast soon so I can tear into this on a day off!
See what kind of voltage your getting on both ends of the small wire. This will shed light on whether it is too small.
If you need help following the wires lemme know, I have a wiring harness that I pulled out of a car ('92) that I can look at. Quote:
![]() After ALOT of current and voltage drop testing, plus pulling apart the steering column, and the harness that goes through the firewall, I discovered my issue (over a weeks worth of work later!) It appears that on one of the times I put my starter back in (after the 5 speed swap, I'd pulled the starter on 2 more occasions to deal with the occasional starting issue by cleaning the starter and solenoid, which I later realized was probably relay related). Anyway, on the most recent installation, when the car worked perfect for 6 days then completely died, it appears I installed the control wire connector on upside down. It was just sitting down by my starter solenoid waiting to be plugged back in. I'm assuming it wiggled off over those 6 days. This time I made sure to install it the right way so I hear the CLICK! She turns over and starts every time now. Lets hope this lasts. And for gods sake if you're having this problem, check all your connections before you tear the car apart! ![]()
I know the clutch position switch is in the circuit somewhere because my "fix" for my click-click no start issue was to run a wire from the starter interrupt relay (the one on the steering column) straight to the starter solenoid. Starts every time with that setup, but It also bypasses the clutch position switch because now it will start with the clutch out. Not a huge deal to me, and I could leave it this way if necessary, but I'd like to keep it operating via the clutch. I checked the voltage going to my clutch switch in the "start" position and it's good (12v), so my feeling is that i have an issue in the security module/inhibitor switch which occasionally causes voltage at the starter solenoid in "start" position to fall to 6v (because the clutch switch itself checks out OK). This fact makes me believe that the clutch position switch is located in between the starter interrupt relay and the inhibitor switch. True? It's looking like my final fix will be to run a wire from the clutch position switch directly to the starter solenoid so that it gets sufficient voltage every time. Will this have any tradeoffs other than losing my theft deterrence (which I keep "off" anyway because I don't have a FOB and don't like when I occasionally accidentally trip the alarm)? Mat
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ![]() ![]() I don't care if Subaru says it's STI...it will always be STi to me ![]() Last edited by SVX10; 04-19-2011 at 10:48 AM. |
Keith ![]() |
#28
So I went ahead and ran a wire straight from the clutch switch to the starter solenoid. Problem is that this cuts out a tie into the MPFI module, so it starts very sluggishly. Additionally, it didn't work every time either. I put in a new clutch position switch and that fixed it, for a few starts, then it went back to not working. Finally i soldered some of the connections to the clutch switch and so far it's been working fine. Might have just been a loose connection in the wiring to the clutch switch!
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ![]() ![]() I don't care if Subaru says it's STI...it will always be STi to me ![]() |
