Old 03-29-2011, 10:07 AM
Subaru Alliance Subaru Alliance is offline
injector o-rings?
i have been driving the 94 svx around for a while, and it does have the ole leaky injector issue. I have 6 injectors from an SR20 engine, and connectors from the twin turbo 300zx and i would like to install these injectors and connectors. my question is this: I want to replace the o-rings on the injectors before i install them, should i try to find an o-ring kit for the svx, or use one for my specific injectors, or is it more of a universal type o-ring kit?
I have never bought an o0-ring kit for injectors before, If I order one for my injectors, it would come in sets of 4, that's why i was thinking of ordering for the svx to get it into a set of 6, and if the injectors are a direct replacement, shouldn't the o-rings between the two be the same?
I am not sure so fire away.
I appreciate the help.
2003 Baja Sport
1994 SVX LS
1992 SVX LSi parted out
Old 03-29-2011, 11:20 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: injector o-rings?
the injectors for the sti/svx/sr20s and so on all use the same o-rings
I installed the SR20 injectors last summer i just went to nissan and got them for i think it was $18 for all 12 rings.
pretty much you can buy them individually, remember there are 2 orings per injector.
I'm not sure what will happen if you put the sr20 injectors in with a stock ecu.
I have the ECU-TUNE stage 2 chip which works with the Z32 maf and SR20 injectors
Old 03-29-2011, 11:24 AM
Manarius's Avatar
Manarius Manarius is offline
Yeah, the rings from Nissan cost less than half of what they are from Subaru.
-Jason
-Obi Wan Kenobi
Old 03-29-2011, 07:06 PM
I appreciate the help. I will post whether or not there are any issues with running the sr20 injectors on the stock ecu
2003 Baja Sport
1994 SVX LS
Old 03-29-2011, 07:34 PM
Cam Cam is offline
From my understanding of the software in our cars, which I will admit is very elementary, I expect you are going to run WAY too rich. Honestly, I would be surprised if the car ran... or even if it started. The ECU tells the injectors to open for a certain amount of time. The injectors are designed to flow a certain amount of fuel for a fixed amount of time. Your 370cc SR20 injectors are going to flow roughly 40 percent more fuel. If your ECU sees this and leans the fuel map out, it may run, but it will be much too rich.
IIRC the SVX injectors are 260cc...maybe 240?
So in the time it takes our injectors to flow 260cc (or 240cc), those SR20 injectors are going to flow 370cc.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-29-2011, 09:15 PM
Once again Cam is correct!
Old 03-29-2011, 09:16 PM
Cam Cam is offline
do I detect a hint of sarcasm there tom?
Cam
'92 Ls-L Dark Teal
Old 03-29-2011, 09:51 PM
NO! ABSOLUTELY NOT!
Sending PM.
Old 03-30-2011, 12:01 AM
Gamesy's Avatar
no he's come to the conclusion that ur starting to replace him for info guru status :P
Old 03-30-2011, 09:01 AM
wouldn't the flow from the injector be regulated by the maf, throttle position, load on the engine, and the o2 sensor?
i understand it is a bigger flow injector, but that wouldn't mean that it flows at max capacity all the time.
I am slowly gathering all my parts around for an ecutune stage 2 turbo build, i have the injectors and connectors, as well as the turbo. just waiting for pistons, and some small miscellaneous parts.
wanted to see if could kill two birds with one stone on this leaky injector.
well i do see what your saying tho, if i give it enough throttle for the ecu to figure load and all this and it tells the injector to increase the flow and duration by say 20%, it's configured for 20% of the stock injector.
2003 Baja Sport
1994 SVX LS
Old 03-30-2011, 09:03 AM
next time I will try this new thing called thinking before I post. I pretty much answered myself. thanks
2003 Baja Sport
1994 SVX LS
Old 03-30-2011, 02:11 PM
Gamesy's Avatar
you dont need a turbo to install the stage 2 ECUTUNE setup
i have it installed on my car
so if you're gonna pop off the injectors might as well install the new ecu/MAF and injectors at the same time
