Front U Joint?
I need to replace it - where the heck can I get one, and what do we call it in SVX world? The only thing I can find is the driveshaft, which is not broken. Do I have to buy the whole thing or???
Re: Front U Joint?
Unfortunately the U-Joints in the SVX were not designed to be serviceable or changed. However, someone thought a way around that. I haven't changed the ones in the SVX, but I have changed the ones in my 240SX which are the same part and so should be the same process. Be warned, it's not a quick job.
Here is a link to a site that sells them. RUJ-10 is the one you want. If you get a shop to change these for you, speak to the tech and ask if they've done import style staked in U-Joints before. As an alternative, if you can be without the car for a little while remove the driveshaft and bring it to a good driveshaft shop. They will be able to fix you up properly.
Re: Front U Joint?
The driveshaft is fine. It's the front u joint I need..........sorry but I'm clueless. But I have a great guy that does all the work on my cars and he is good.........
Jen ![]() |
Duh - just went to the website and that's exactly what I was looking for! Thank you!!!
Jen ![]() |
Yeah. First it started shaking when I took off from a stop, then started shaking most of the time. If you punched it, the most god awful clunk came out from right under the arm rest. My mechanic friend and I crawled under it, and where the driveshaft goes in to the front u joint, you can see where it is off center - the metal is wearing off of the front u joint. So it is in the garage until further notice.................. nothing new there!!!
Jen ![]() |
Re: Front U Joint?
Oh yeah - it's a 92 AWD Lsl
Jen ![]() |
Re: Front U Joint?
Do you have any other ideas? This car is in such nice shape - no leaks, no electrical problems at the moment - - - - so I am trying to keep it that way!!!
Jen ![]() |
Re: Front U Joint?
Ya when i did my 5spd swap the guy at the driveshaft shop said that they were not designed to be serviced, just replaced with a new driveshaft because these things are pressed/clamped in(thats why there are no C-clips) In order to change the u-joint the old one will need to be drilled out and the the process be annoying. he said it was gonna cost about 4-500 so i just paid 550 for a new driveshaft to be made with bigger beefier U-joints that are serviceble and u can change in like 15mins. (GM SUV u-joint) and they are only like $15 each.
In the end i think its worth it to get a 1 piece driveshaft made cause u dont have to worry about the carrier bearing wearing out and those are also another expense and apparently this was my 1,001th post!
