Old 12-18-2010, 02:48 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Transfer clutch engages with a THUD
So now that its snowing here, I have discovered that after about a half-second delay my transfer clutch (and the rear wheels) engage with a thud sound.
I have been having a slight problem with my wheel sensors, my ABS will always kick on when I apply the brakes in reverse.
So is that maybe why the transfer clutch engages so harshly maybe? I admit I dont know much about that part of our drivetrain, so any insight would help, thanks fellas!
Old 12-18-2010, 04:53 PM
oab_au oab_au is online now
Re: Transfer clutch engages with a THUD
The ABS should not have anything to do with it Chris.
The thud is a delay in the action between the TCU signal to the C solenoid and the transfer clutch piston applying pressure to the clutch. It allows the front wheels to start spinning, before the rear is engaged.
It can be caused by the Transfer valve sticking in the valve body, needing more pilot pressure to move it.
An oil pressure leak in the clutch cylinder.
Or the actual clutch plates have worn down too much.
It is this type of delay that breaks the clutch hub off the transfer gear, so I would not let it happen too much.
One Arm Bloke.
Tell it like it is!
Old 12-18-2010, 06:53 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Im glad I asked. Thanks Harvey, I guess ill keep it FWD until I really need to use it.
Edit: Question, so how does the TCU detect the front wheels are spinning?
Old 12-18-2010, 08:34 PM
What He ^ said!
Old 12-18-2010, 08:52 PM
2 speed sensors. One in the front diff (front wheel speed) and one in the tailshaft (rear wheel speed). TCU compares the speeds and if the front wheels are spinning faster than the rear, it engages the transfer clutch.
Old 12-18-2010, 09:30 PM
Chris, it's better to not let it be in FWD mode as the transfer clutch is much easier and cheaper to replace than the front diff. Transfer clutch replacement is about a 3 hour job, compared to about 10 or more billed hours for a diff replacement as the entire transmission must come out.
This was happening on my silver SVX before I pulled out the junk stock transmission and put in the 4.44's.
As long as you are easy on the gas in slippery conditions, It will prevent the front diff from getting any abuse and the transfer clutch from getting any more damage. Just take it easy in the slippery conditions and when money allows for it, go ahead and get yourself a new or new to you complete transfer clutch assembly with the drum and replace it.
Old 12-18-2010, 10:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
So what I was asking earlier was if these could be causing the delay for my xfer clutch..... they trip my ABS when I brake in reverse, meaning they are falsely detecting wheel lockup maybe? So one or more speed sensors maybe bad, this can be ruled out as a cause?
Old 12-19-2010, 02:41 PM
No the gearbox speed sensors and the ABS wheel sensors are not connected. The ABS problem in reverse is different to the Transfer delay.
You could try some additive in the ATF, to see if it will free up the transfer valve, which is probably the cause of the delay.
One Arm Bloke.
Tell it like it is!
