spark plugs
what is the best spark plugs i should put in my 1996 svx
Re: spark plugs
NGKs are very well liked. Best you can afford as they're not the easiest to put in. Not hard, just a little bit of time.
Re: spark plugs
NGK Iridium IX in mine.
Re: spark plugs
Same here. 40k miles and still strong.
Installed in spring '03.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() Last edited by NikFu S.; 09-01-2010 at 09:26 PM. |
Re: spark plugs
NGK Iridium.
And you can install the in NINE MINUTES! ![]() ![]() OK, inside joke. Expect two hours for 1-5, and 2 hours for #6, the first time. ![]() YMMV
Re: spark plugs
![]() I actually put off doing my plugs for an extra 6 weeks from fear of the driver side bank, and afterwards it was like "that was it?". Not saying its easy easy, but I never understood the trouble people have with it. |
Re: spark plugs
![]() I got down to about 10 minutes for that plug after repetedly changing that oil fowling plug. Practice helps speed.
Re: spark plugs
![]() tee hee... jk |
Re: spark plugs
Ha! I broke a nail the other day and only cried for 15 minutes. Girly........ pffff
Re: spark plugs
my god i did mine las weekend....WHAT A PAIN IN THE A$$$
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill Last edited by Francis; 09-02-2010 at 10:40 AM. |
Re: spark plugs
Re: spark plugs
The hardest part of changing the plugs in mine was getting the ##2@@$% boot from the coil off the plug.The thing was hard as a rock and I used a pick to get the pieces out. That was 20 min. alone. The rest was a snap.First time maybe one hour+/- I bought a couple of boots for spares.
Re: spark plugs
i replaced all six plugs in 45 mins
Re: spark plugs
Re: spark plugs
for thr first time ever doing it that cant be bad
