Old 08-26-2010, 01:57 PM
Pierre-Olivier's Avatar
Pierre-Olivier Pierre-Olivier is offline
Exclamation Helpe me !!
Hello everyone,
Why my SVX is trembling at very slow speed by pulling the steering wheel to the right or left?
Thanks.
Pierre-Olivier
Old 08-26-2010, 04:44 PM
oab_au oab_au is offline
Re: Helpe me !!
Originally Posted by Pierre-Olivier View Post
Hello everyone,
Thanks.
Pierre-Olivier
Pierre, if you mean that the steering wheel "trembles" when you turn it. It may be air getting into the power steering pump. It may be the "O" ring under the pump tank, letting air in.
One Arm Bloke.
Tell it like it is!
Old 08-26-2010, 05:01 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Helpe me !!
If it vibrates the wheel back at forth while the car is moving at slow speeds it could be;
- While braking it could be "warped" brake rotors or bad control arm bushings.
- While driving at slow speeds it could be bad/binding front axles.
Old 08-27-2010, 12:51 AM
Re: Helpe me !!
Thank you, what is it "O" ring ? How to remedy this problem ?
I changed the power steering pump, it is new !
Old 08-27-2010, 01:17 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Re: Helpe me !!
O ring is a round gasket.
How you check the oil level on the steering pump?
Maybe the rubberpipe is leaking?
Is the anny oildrip under the car when the enige is running?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 08-27-2010, 09:48 AM
Re: Helpe me !!
Hello, the power steering oil is leaking, is it necessary to change the tank ?
Old 08-27-2010, 10:08 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Helpe me !!
Replace the o-ring under your fluid tank, they tend to harden and leak. Try this before replacing the pump. O-rings shown are for illustration purposes only!
Old 08-27-2010, 11:09 AM
Re: Helpe me !!
Thank you SoCal LS-L but which "o" ring on this image ? what ref number ?
Old 08-27-2010, 03:08 PM
Re: Helpe me !!
doubloon, sorry.
Old 08-27-2010, 03:09 PM
Re: Helpe me !!
doubloon, sorry.
Old 08-27-2010, 05:33 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Helpe me !!
Oh im not sure I just threw in a pic of some since you asked. Im sure someone else knows the exact dimensions.
Old 08-27-2010, 06:13 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Helpe me !!
Power steering o-ring replacement = p/n 062610110
TREVOR supplied information on the o-ring size in the "how-to" area, about 5+ years ago.
It only takes 30 minutes to change & it was the cause of my issue.
Old 08-30-2010, 02:06 AM
Re: Helpe me !!
Do you have a link ?
Old 08-30-2010, 02:27 AM
scoobymal's Avatar
Re: Helpe me !!
I bought a box full of all sizes from my local car parts store,really cheap £2
Old 08-30-2010, 01:30 PM
SURTEESS's Avatar
Cool Re: Helpe me !!
check out the top area of the page -
Steering
O-ring
