Helpe me !!
Hello everyone,
Why my SVX is trembling at very slow speed by pulling the steering wheel to the right or left? Thanks. Pierre-Olivier |
Re: Helpe me !!
Harvey. |
Re: Helpe me !!
If it vibrates the wheel back at forth while the car is moving at slow speeds it could be;
- While braking it could be "warped" brake rotors or bad control arm bushings. - While driving at slow speeds it could be bad/binding front axles. |
Re: Helpe me !!
I changed the power steering pump, it is new ! |
Re: Helpe me !!
How you check the oil level on the steering pump? Maybe the rubberpipe is leaking? Is the anny oildrip under the car when the enige is running? |
Re: Helpe me !!
Hello, the power steering oil is leaking, is it necessary to change the tank ?
Re: Helpe me !!
http://i756.photobucket.com/albums/x...gsizechart.jpg |
Re: Helpe me !!
Re: Helpe me !!
doubloon, sorry.
Re: Helpe me !!
doubloon, sorry.
Re: Helpe me !!
Oh im not sure I just threw in a pic of some since you asked. Im sure someone else knows the exact dimensions.
Re: Helpe me !!
Power steering o-ring replacement = p/n 062610110
TREVOR supplied information on the o-ring size in the "how-to" area, about 5+ years ago. It only takes 30 minutes to change & it was the cause of my issue. |
Re: Helpe me !!
Re: Helpe me !!
I bought a box full of all sizes from my local car parts store,really cheap £2:)
Re: Helpe me !!
check out the top area of the page -
How-To Documents Steering O-ring |
