Hood and Trunk Strut Redo Redux
WATCH THIS SPACE! I'll update this thread with the hood and trunk strut rebuilds, using aftermarket bits. Everything you need to know. Every cut, every part, every spec. Complete: Everything is installed! Next: The How-To! Experiment results so far: * The 90# struts make a much better replacement up front than the 120# ones; they still lift the hood themselves, but they're definitely more civilized when closing. * The measurements made in the original hood strut How To are short about an inch and a half. Thanks to John for the correction. * With both 80# struts installed in the trunk, it won't pop it up, and it won't let it float down, so keep the kids' fingers out, but it does move in a much more friendly fashion. You still have to control its speed, but it's with a lot less effort. For note: My trunk has the wing. * The trunk strut mod is currently facing a problem that was pointed out to me. Hood struts are still super good, though. Bill of Materials (in progress): I got these from ASRaymond: Qty P/N Item Price Extended 2 GSNI225090 Gas Spring - Black Nitride (hood strut) $16.19 $32.38 2 GSNI515080 Gas Spring - Black Nitride (trunk strut) $14.13 $28.26 2 BS1002 Ball Stud $ 1.02 $ 2.04 6 BS11208 Ball Stud $ 1.39 $ 8.34 Shipping $13ish $13ish $84.02 You'll also need: (6) 1/4-20 nuts, stainless steel, which should cost about $2. (2) washers - I used 6mm, with the smallest OD I could find. About $1.00 Paint for the brackets, if you're the type that doesn't care for exposed metal Get some cutoff wheels for the Dremel, too! .
Disclaimer: The above post is on the internet. Last edited by svxcess; 11-25-2018 at 08:18 PM. |
Hi, I have done the hood strut mod, originated by LetItSnow. Read 1st thread (NOT the trunk mod) and it is easy to do and works excellent for about $50.00 Slightly modified BOM Qty P/N Item Price Extended 2 GSNI225090 Gas Spring - Black Nitride (hood strut) $16.54 $33.08 4 BS1002 Ball Stud (hood strut and base) $ 1.02 each $ 4.08 2 M8 Nuts $ ~.75 each. $1.50 a pair Shipping $13.00 approx. ~$50.00 EDIT: The 10mm ball stud (BS1002) with 8mm shank fits the oversize hole in bracket with reused plastic bushing better than the original stud with 1/4-20 shank. ,
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k Last edited by svxcess; 11-24-2018 at 08:35 PM. |
Never noticed that sticker before, if going over 150 MPH increase tire pressure to 40 psi :O 150 is damn fast!
Is there a way to do this without tapping or drilling? I don't have those tools at my disposal
1991 SVX L JDM 1992 SVX LS-L USDM 82 911SC Targa, 89 325i Convertible, 96 XJR, 08 LR3 SE Last edited by svxcess; 11-24-2018 at 08:22 PM. |
Re: Hood and Trunk Strut Redo Redux
Wow, a lot has happened since Mike's post above - he's had my strut mod on for a while now!
I don't know exactly where my completed writeup went, but this picture tells the story. (EDIT, it's over <here>.) You essentially split the strut's bottom bracket and keep just the part that mounts to the body. The hole in the bracket is rather large, so placing a washer inside it allows a ball stud to hold in place. No tapping, no place for wobbly bits, no grabbing the strut rod with vice grips, and no obstructions if you choose to blast/sand/paint. There's not much to it. ![]() I know this is quite a bump, but the thread was linked to today, so I figured I'd finish my part!
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 04-05-2010 at 04:33 PM. |
Please post those actual SPD part numbers for the struts again, along with the ball studs.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I redid my hood struts today using LetItSnow's method and it works better than my original modification. I found there is an easier way to do this. Just drill out the rivet that holds the bracket together and discard the rivet. Once the two pieces of the bracket separate, you will find a small nylon bushing that fits perfectly into the hole in the bracket where the ball stud attaches. Insert the bushing into the hole from the inside of the bracket (closest to the engine). It fills the hole perfectly, fits flush and allows you to use the same M8 x 1.25 ball stud that is used on the hood. Insert the ball stud through the bracket hole and bushing (with the ball end pointing toward the fender) and secure with a M8 x 1.25 nut. All you need is listed below. No trimming, cutting. Truly plug and play. [2] M8 x 1.25 nuts [2] nylon bushings [4] BS-1002 ball studs [2] GSNI-2250-90 struts. AS Raymond Gas Springs Page Toll-free Phone: 1-800-720-2633 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-24-2018 at 09:23 PM. |
Re: Hood and Trunk Strut Redo Redux UPDATE
There is an additional update to the gas strut numbers. I received this information from Ed Del Monte "ZMan". He has been in direct contact with tech support at SPD and found out the following information. There is another strut that can be used in our hood applications that allow our hoods to open even further. It is a new addition to their current lineup. The other strut number is SPD GSNI- 2449-89 As you can see by the specs, it is rated at 89.9 lbs. force, instead of 90.0. The rod diameter, tube diameter and price remain the same, but the extended length is .6 inches longer, the compressed length is about .36 inches longer and the stroke is about .37 inches longer. He installed them on his car and has confirmed that they fit without any issues and the hood opens appreciably higher than the 2250-90 struts in this original modification. We will get exact measurement differences in opening height between these two struts, as well as comparing them to the stock units, and post those numbers. Thanks to ZMan for stumbling upon this. ...... http://www.asraymond.com/catalog.html?cid=ha-standard&id=GSNI244989 800.872.7732 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-24-2018 at 08:31 PM. |
Here are the measurements of the hood openings for the various struts. ZMan provided the measurements from both of his SVXs, one with original OEM struts and one with the newer 2449-89. I have the 2250-90 struts on my polo for measurement. My 2250-90 struts open 1" less than stock. The 2249-89 struts open 1.5" more than stock The SPD struts go for $32.38 a pair; the OEM struts are $150.72 a pair from subaruparts. List is $197.80 a pair ![]() The OEM struts measure 18.5" from center of ball on hood to pivot point on the strut bracket (which is where the new struts attach) .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-24-2018 at 08:29 PM. |
John - now it is time to do the same thing with the trunk struts.
We have tried many types of alternative struts fron NAPA, etc. Finding the right length (both compressed and extended) and the proper pressure is not easy. What is the pressure rating of your struts? 90 lbs is an reasonable number; fairly stiff in the warmer months and a little easier in the winter. Anything with less pressure will have a harder time in the winter after a while 110-120lbs is too strong and could cause problems. I also found that the SPD struts, at $16.19 each, are cheaper than auto store units. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-07-2021 at 09:45 AM. |
+1, Trunk struts seem kinda urgent, at least to me. Gotta stop the "Don't slam the *thud* trunk...".
Gsodonis did the mod using Strong Arm gas charged lstruts #4468, but they don't open as far as OEM. ...... His writeup can be found HERE The OEM trunk struts are a lot cheaper than the OEM hood struts, about $50.00 each 57521PA000 RH 57521PA010 LH .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-25-2018 at 08:07 PM. |
Amazing presentation skills ![]() Thanks John ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
Re: Possible trunk strut alternative
Here is a POSSIBLE trunk strut replacement (also from SPD) First the specs of the OEM trunk struts. From pivot to pivot, the stock trunk struts have a compressed length of 9.25" and an extended length of 13.625" The Strong Arm 4468 trunk struts used Gsodonis's writeup have a compressed length of 8.9", but an extended length of only 13.1" (which is shorter than stock and the reason why the trunk does not open fully) SPD has a strut GSNI-4340-78. This strut has a compressed length of 8.81" (similar to the Strong Arm) BUT a longer extended length of 14.81". This should allow the trunk to open slightly past 90° until stopped by the hinge. You could drill the ball stud mounting hole on the bottom bracket further back to shorten the throw. This strut has a pressure rating of 79 lbs. Should be worth investigating... .
