Old 05-01-2010, 06:03 AM
Accepted to grad school! Summer plans
So, there's now a week left in my last semester before graduating with a bachelors in biomedical sciences. One final exam and one research paper, and I'm done. Well sort of. I just found out I got officially accepted to a graduate program about a week ago. I'll be coming back in August to start grad school at the same school, in the same research lab where I've been volunteering for the past year, to start working toward a PhD in Organic Chemistry. Needless to say, the wife and I are super excited.
So, seeing as how the next 4 years are going to busy with research, I've put together a little list of all of the car projects I want to get finished with over the summer:
SVX:
6-speed swap -clutch/flywheel/pressure plate have been resurfaced. found out it's a ~2600 lb pressure plate and got a stage 1 clutch.
poly bushings
konis/dayle's springs -changed my mind, G/C coilovers instead, which have also arrived
brake fluid/pads - done (Redstuff pads f/r and superblue)
plugs
stebro exhaust
wheel bearings
maybe some interior work
apkarian's LED tails
The majority of these parts are sitting in my garage, ready to go as soon as I get a chance.
Also be helping to get my brother's 240 put back together now that the motor's built and together:
240:
put engine back in -done
change ecu to SR20DE ecu -wiring harness about halfway hooked up
wire-in boost controller and ecu piggyback
trunk-mounted battery -all the wiring is done, gotta mount the battery itself
Update: We just discovered the hood doesn't shut all the way. Gotta figure something out, but most likely it'll end up looking like tom's beast.
What do y'all think? Any other miscellaneous maintenance I should do while I have the car all apart? I need to order some valve cover gaskets and cam seals to do those as well, anything else I should reseal while I'm at it?
I could also really use some general advice on the 6-speed swap. I'll post pics of all the parts I've got for it later.
Old 05-01-2010, 06:45 AM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Re: Accepted to grad school! Summer plans
You are a crazy man. but good luck. I think you are going to be busy.
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 05-01-2010, 08:16 AM
SVX_MY_BABY's Avatar
check the rear trailing arm bushings and rear diff bushings. You will have it apart anyway so may as well replace those too.
Peter
Old 05-01-2010, 09:53 AM
LetItSnow's Avatar
My 10th Subaru is a WRX
My rear diff bushings were all but destroyed! I'll second that!
Old 05-01-2010, 02:44 PM
Trailing arm bushings are part of the strongflex (polish) bushings (correct?), and new rear diff mounts are sitting in a box next to the 6-speed I really wanted to get some of the poly ones from earthworm, but I think he stopped making them or something.
Old 05-02-2010, 12:58 AM
Stock sti shiftknob w/cobb shortshifter:
The strongflex bushings:
The car it's all going into:
Old 05-02-2010, 01:33 AM
.................................................. ........................cobb shortshifter .................................................. ....................................:
Old 05-19-2010, 03:25 PM
Banned
really clean SVX I'd love to help you out in the future gettin that baby turboed! It'll look nice with those LED tails you just bought
Old 05-19-2010, 03:50 PM
Yea couldn't resist. First post updated.
Old 05-19-2010, 04:41 PM
NeedForSpeed NeedForSpeed is offline
Better work fast, summer daze won't last
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-19-2010, 10:41 PM
Yea seriously. Gotta get the 240 running first before any real work can begin. Can't have 2 cars down like that.
Old 05-20-2010, 01:05 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Redstuff pads will stop that thing on a dime, I have them on the fronts and hawks in the rear.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-20-2010, 01:54 AM
Yea they do feel better than whatever ones were on there. Actually I got them based on an old post of yours thanks
Old 06-03-2010, 06:14 PM
Update: Well, I decided not to attempt the 6-speed swap myself and have most everything done at a place called S&R here in Tampa. Hopefully it doesn't cost too much, but I figure best to let them at it than do it myself and have something go wrong.
Old 06-10-2010, 04:41 PM
Banned
it's really not all that bad, most of it is nuts and bolts, very little fab and custom work...
Save your money you'd spend in labor for more mods
