Re: Stereo power issue
Ok finally got the car back and got the alternator/battery checked which turned out ok. That's one thing down, Checked the gound behing the intake manifold and it was disconnected. I reconnected it and drove around the block and it still shut off. The rotted looking ground infront of the battery tested ok for ground still so it's not that. Gonna have to sift threw my schematics for common grounds
![]() EDIT: just checked the book and the radio has it's own ground and the antenna has its own as well. Just for laughs I removed fuse#22 for the antenna assuming since the radio and it get power from the same source it may have a short in it. Drove about 5 ft and it still reset. It may well be the deck now, also I don't think this is related but my sub cuts in and out, put a test light on the positive wire to the sub and it showed solid blue for ground and blinks red for power when the sub hits. I think I may have shorted it.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress Last edited by redlightningsvx; 05-19-2010 at 03:24 PM. |
Hi Seth,
How did you test the ground from battery to body ? I ask because if was with ohmmeter "statically" Then you may still have a problem, in that the resistance could change "dynamically" or "under load". It is easier for the DIY mechanic to add a second ground known/assumed to be good (clean metal, virgin connections) to test than it will be to measure ground resistance under load...
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
I tested it with a volt meter.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
I'm going to wire up an old deck tomorrow and see if the symptoms stay or go away. By the looks of things my newish cd player is crappin out.
My deck died durring install. Worked when I pulled it from my RS.
Installed it in SVX, it would light up, but no power. Spent hours tracing things thinking the ACC Lead was fried. Bought new cheap deck, installed it. 5mins later it was working.. Turned out to be internal to the deck. |
Just wired up a new/old deck to just the red,yellow,black wires to just get it to turn on. Drove around the block and it didn't shut off so it looks like i'm getting a new deck and probably sub very soon.
What kind of deck are you going to get? Let us know what you get and how well it fits.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Probably going to get the same deck again as it has all the features I like- low,mid,high,sub out volume, aux volume.
Update: The alternator that tested good about a day ago craped out today on me in the middle of the highway. I got a new one coming Sunday morning so the deck still maybe good. I'll post results when it's installed.
Your really having a crappy week aren't you.
Radio, tints, alternator .. when it rains it pours doesn't it. Feel for you man. Hey don't know if you saw these, but may be an option: High output SVX alternator: http://www.maniacelectricmotors.com/hiou160ampal6.html I don't own one, got the link from this site though. When mine dies I am buying one. |
This is the only car I drive so I got one at advance. About $165 w/o core which sucks but i'll have it sunday by 10am. Maniac one is $80w/o core but having it shipped in a day or so would only be about $20 less than the one I got ordered.
I new something was wrong when I started to drive to Altoona to pick up a new coolant temp sensor the brake light,ABS,battery, stop lamp were lit solid the whole way down and on the way back they started to flicker while hitting the brakes, clock and cluster needles jumping around and the stereo shut off while driving about 15 times back to back before I shut it off and had it rollbacked to my buddies. Also to top it off I have to replace the radiator.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress Last edited by redlightningsvx; 05-21-2010 at 08:14 PM. |
Wow you got alot of little things adding up there don't you. Still a great looking car. Hopefully the Alt. will fix your stereo issue. Are you doing the coolant temp sensor due to starting issues? Surprised you drove to get one rather than order it direct to your door. What are you planning for the Rad? I know PWR is kinda high but likely the last one you would ever need. Plus it would look nice in your engine compartment
#28
I'm doing the coolant temp sender because I've had a random temp gauge reading and I just got a cheap rad for now as things are adding up this week and I need one quick before I go on vacation. I ordered one at my old job because I still get Subaru discounts
#29
![]() Harvey.
#30
Im going to have to agree with this being a good suspect.... I wouldnt toss your head unit just yet.
