Re: new coilover opportunity (March, 2010)
Double post...
You might want to post this somewhere it will get more attention than buried in a sub forum of mod mania... If I can get a set that would have in the ballpark of 600lb springs I will be in 100%...
Mychailo well hi long time no hear,
I would like to put in my 2 bob worth. As you guys may be aware I have DMS struts which are great but can be a pain. They have bushes and a reverse tube so it is impossiable to stop the strut jaming after a period of time. They are also adjustiable in both direction, but the minium is still pretty hards so on a road car you nearly lose your teeth driving it. Next point due to these and other factors they have to be pulled down every 50,000 k to rebuild, that means I have had mine out about 5 times since installing them. Based on the above I thing these look good, I would like to know what brad damper etc also is it like the Koni with a shaft at the top or is it like the DMS with a tube. Tony
Good to see you are still in the SVX game and sorry I didn't back to you last summer. Life is pretty busy these days. Anyhow, these are a monotube damper, not inverted, so the shaft is above. The product is designed and built entirely in-house at AMR. Are you considering putting a set in your offroad SVX? If yes, I think you'd need a custom offroad design.
Mychailo,
Yes I am trying to find a better strut, The DMS are tough but for me they have two faults they work in the up and down direction which tends to give a rough ride on dirt at speed & fact you can't fit boots over the top of the strut tube means it builds up with mud as stops moving up and down. You may be right about needing a tougher one. I will know soon but I think I even bent one of the Dms which show what punishment they get. Tony
Hmmm this is a tough one.. even at the lowest spring rate (275lb) we are still higher than most aftermarket "sport" springs for Evo's! I loved my Evo but I cant say I want my SVX to ride as firm. If only we could get that spring rate down a bit more.
The front spring rates are most comparable between the SVX and Evo because both have a MacPherson strut design. Stock Evo is about 200 lbs/in (measured it myself), while the GTWORX springs are 290 lbs/in in the front, the Swift Sport springs settle at about 270 lbs/in in the front, and the Swift Spec R front spring settles at more than 300 lbs/in. So, the lightest available rate for the SVX coilover is comparable to the rate of the better sport strut springs for the Evo (and way lower than all standard coilover spring rates for the Evo). I'm sure you know that there are other contributing factors, namely the damper response. Anyhow, these are definitely a sport oriented coilover.
Thanks for a good response. Those seem to be in short supply on this forum. I actually ran the Swift Sport springs on my Nur spec Evo VIII. We lived in England back then and I thought those made it a bit too skittish on those bumpy British "B" roads. Granted we have, for the most part, better roads here. I understand we are dealing with about 600lb of more mass & a totally different intended purpose with the SVX. What are the stock spring rates for the SVX? I'm not trying to waste your time but put the pieces together to decide if this is a worthwhile pursuit for me. BTW I used the same username on EvoM but add an ! on the end. My 2005 GSR made 350whp/330lbft at 21psi on a stock VIII turbo with the basics, FMIC & chargepipes, TBE, Intake, tune and....Oh yeah 272 cams running -4/-1. Damn I should have never sold that car. I think I still hold the record at Mase Engineering (dyno dynamics dyno) for the highest WHP on a stock turbo VIII w/o any power adders. But then when I sold it gas was hitting $4.50 a gallon! Add in 180 miles to the tank... you get the picture. LOL But then I am sure with your numbers this isn't anything new to you. Last edited by Bonestock; 03-27-2010 at 04:25 PM. |
I am getting a a set of Tein made up - will keep you in the loop if you are interested. These are able to be serviced/ revalved locally - they have a set of complete struts I sent them and are coming back with a couple of options - our struts using inserts, coil over set up with height &/or dampener adjust or complete new setup. I've been slow on chasing this up till now due to my engine problems - now fixed ![]() bruce
Tr = [(Zp1 X Zs2) / (Zs1 X Zp2)] x T1 Tf = 1 - [(Zp1 X Zs2) / (Zs1 X Zp2)] x T1 |
Its not quite a fair comparison to look at how a stock Evo damper is going to handle a spring that is 35% stiffer than stock especially because the stock Evo KYB strut is not such a great strut.
Anyhow, the stock SVX spring rates are 140 lbs/in in the front and 110 lbs/in in the rear. They are amazingly soft. I think the only reason the SVX doesn't bottom out on every bump is because it has so much wheel travel. Considering that the SVX weighs ~400 lbs more than an Evo, a 275 lb/in spring isn't so heavy, and a proper rebound setting should make them ride on the firm side but cleanly. 350 whp with mild mods is definitely good on a DD dyno.
I ride in a couple cars that are coilover equipped on a regular basis. One is a 240SX running Stance suspension with 450 front/350 rear spring rates. The other is a Prelude running Tein Super Streets with 450 front/225 rear. I don't find either to be unpleasant to drive, even on the garbage roads we have around here. Obviously neither has the comfort of the SVX, but when modding a car it's very seldom possible to have both worlds. If you want performance and handling, you will have to sacrifice comfort. If you want your car to soak up every bump and ride like a Caddy, it will probably handle like a tank.
#28
You see I have a problem with that blanket statement. I'll tell you what. Grab yourself a ride in an Evo and then a STi. The Evo will impart a sense of absolute control with razor sharp steering response. Great right? Well on a smooth track there isn't another 4dr car on the planet that will do the job better. Yet get that same car on a bumpy, uneven road and all of a sudden its firm suspension, bushings and super fast steering become more of a liability. Now enter a known "softer" STi and while not near as good as the Evo on a track, get it on a bumpy road (I prefer dirt!) and OMG, you know exactly what Subaru was on about. Its planted and soaks up the bumps and such that would have an Evo in the ditch. ![]() Now consider that most of us will never push a SVX around Silverstone or Laguna Seca, a really firm non-compliant ride serves what purpose? ![]() ![]() I worked for BTCC driver Gareth Howell while I lived in the UK and he taught me a few things. One premise can not be debated.... "Build a car for its intended purpose with parts designed to work together properly". So with that in mind could the SVX tolerate a 135lb spring rate increase w/o sacrificing ride compliance and handling? Do we wonder about other suspension components like ball joints & bushings tolerating the increase? I mean we are doubling the spring rate at just 275lb. I dont know to be honest. I'd love to drive one with that set up to find out. I am REALLY interested in these coil overs. Now if we could get some feedback on them once installed. Granted everything is subjective when dealing with what each of us may find acceptable. As always, YMMV. ![]() |
#29
Update...I dropped off a complete set of spare struts at AMR Engineering and had two meetings witht the owner, Andy Reyes - info@amrengineering.com. I do not pretend to be an expert but from the research I have done, Andy's products are extremely high quality. His plan is to develop a coilover specifically designed for the SVX and offer them on a custom basis. If interested, please send Andy an email, timeframe and/or deposit not required.
sunvalleyray |
#30
