torque converter bolts
anyone got any tips on getting the torque converter bolts out? i cant even get a 1/4'' woble socket on them
Re: torque converter bolts
Unbolt the alternator and use a couple long extensions from the front of the engine.
What He said,Mostly!
Actually, I believe you did say that, a time or 20
I don't has a 48" extension.
well 2 24 inch will do also or 4 12 inch etc you could even take it to 48 1 inch extensions lol
William Last edited by subarufamily; 03-14-2010 at 05:02 AM. Reason: forgot to aDD lol |
Tape those extensions together so you don't have to scream when the connection pops loose in the middle and you struggle to fish the pieces out.
If I was going to do it that way I would use a LOCKING EXTENSION. But hey, if you wanna use tape...
I always got mine with no problem by using a swivel head snap-on ratchet and a standard 12mm socket. A knock off but competent can be found at lowe's for those not wanting to spend upwards of $100 for a ratchet. The snap on variant I love dearly is this one, minus the gross handle. http://buy1.snapon.com/catalog/item....re&dir=catalog But as I said lowe's has a knock off for like 30 or so I believe
Where's the challenge in that ??
any tricks on getting the dang diff and tranny out? got all bolts out tranny lines disconnected, shift cable off, and everything but i cant seem to get the diff n tranny off the 2 studs far enough to drop it down
You certified techs and your fancy tools
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 03-14-2010 at 11:52 AM. |
Lift up the front of the engine.
