Old 03-08-2010, 05:09 PM
PearlieSVX PearlieSVX is offline
manual front wheel dive tranny?
Does anyone know if Subaru ever made a Front Wheel Drive Manual Transmission? And if so what is the name of it and where could I possibly buy one??
Thanks
Old 03-08-2010, 07:42 PM
trophy956 trophy956 is offline
Re: manual front wheel dive tranny?
hi in the USA subaru made 2and 4 wheel drive cars till 1996 model year when they decided to just sell AWD in the states ,if your looking for a trans to use
i dont know how well a lecacy 2wd one would hold up to the power of the svx ,fitting it against the engine isnt a problem
good luck
Old 03-08-2010, 07:58 PM
92 SVX 92 SVX is offline
Though wondering why anyone would want to have just fwd as well.
Unless you happen to have a fwd only svx and don't want to add the rear diff?
Old 03-08-2010, 08:14 PM
It's a little more involved than just adding a diff, but it is possible.
Old 03-08-2010, 10:39 PM
Thanks
That thing would spin LOTS of right front tire.
Old 03-08-2010, 10:57 PM
Brings to mind the SHO Taurus...
Old 03-08-2010, 11:03 PM
10 more HP, and WAY cooler!
but I NEED AWD!
Old 03-08-2010, 11:19 PM
Wikedjuggalo's Avatar
Rebuilding
Good lord why........
Old 03-09-2010, 05:04 AM
You'd want an early Legacy FWD 5-Speed, as the early Impreza's FWD 5-Speed had a different spline for the axles, so they won't work with the SVX axles, the Legacy one should work with the SVX axles
Old 03-09-2010, 09:55 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Ditto but in 94 1/2 the imp went with the same spline count in the fwder as the lego. You could if needed to make your own axles but it would be a pain. A fwder SVX 5 speed wouldn't be my first choice but every fwd Subie I've driven has been a better car then the awd version of the same model.
Old 03-09-2010, 03:16 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Thanks
Try for a turbo FWD 5 speed from a Loyale, early legacy, or XT. I had an 86 Turbo XT with a 5speed. Pretty fast little car.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 03-09-2010, 06:45 PM
dynomatt dynomatt is offline
Loyale and XT boxes will not fit.
You need a Legacy or Impreza one.
M
Old 03-09-2010, 07:59 PM
M
Yep!
Unless you install a 1.8 or 2.7!
Old 03-11-2010, 09:35 PM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
why do you think this?
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
Old 03-11-2010, 10:43 PM
My guess is that Ben will say.
Less weight (true, about 90#s)
Less parasitic losses.(true)
Quicker accelleration.(if you have no wheelspin)
Better gas mileage(who cares)
More fun to tail out.
The parking brake is now a steering tool.
