Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 12-07-2008, 11:01 AM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Re: Hella Supertones!
Originally Posted by Crazy_pilot View Post
I just bought a set and I'm trying to figure out where to mount them. The traditional behind the grille location the Impreza guys use doesn't work on the SVX (too tight). I searched and found someone had installed a set, but I don't know how long it's been since they were online. Sooo, has anyone installed a set, and if so, where did you put the horns?
I can't wait to get these running. 118 dB ought to be plenty to get people's attention.
I'm ordering them. You said that its too tight behind the grille. Was it an impossible fit or just really tight? Is possible to shave some plastic off the back grille?
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 12-07-2008, 01:03 PM
Originally Posted by SubaruSVXCrazy View Post
I'm ordering them.
You said that its too tight behind the grille. Was it an impossible fit or just really tight? It will NOT fit behind the grille. Impossible!
Is possible to shave some plastic off the back grille? No. The diaphragm ans mounting bolt are part of the back.
Look again in my locker HERE. The horns are too large to be mounted together; they must be separated.
The original horns and bracket have to be removed. Here is the driver's side horn, mounted on an "L" shaped aluminum bracket, mounted into the stock horn bracket mounting hole:
And again the passenger side mounting location:
And an attachment of the engine bay, showing driver's horn and approximate location of passenger horn
Old 12-08-2008, 10:40 AM
^^What he said.
There's maybe (and I'm being very generous here) a half inch behind the grille. Not gonna work. I ended up placing mine in the same spot. The only other place I would consider relocating them to is inside the fender wells, to keep the engine bay a little less cluttered.
Old 12-08-2008, 02:07 PM
There is no way to significantly unclutter an SVX engine compartment so that you would notice the difference.
However, I might consider relocating the horns into each wheel well. I am not sure if the sound level would be affected because of the ditectional nature of the diagram.
Maybe down inside the belly pan would be an option...
Old 12-08-2008, 08:18 PM
Make it look a little neater then. I know yours are painted, but mine are still red, so they do stick out and are noticably something that isn't really supposed to be there. Although the effect of people looking under the hood for the first time is always fun, between the red Supertones, Optima Red Top battery, PWR rad, and the big old aluminum manifold, people aren't really sure where to look.
Old 02-05-2009, 02:53 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Bump!
Supertones do fit behind the '97 grill...
I don't have a great picture, but you can see the red peeking through:
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 02-05-2009, 03:35 PM
Well there ya go. Say something's impossible and you're just asking someone else to prove you wrong. Another reason to get a 97 grille for my car
Old 02-26-2009, 12:59 AM
Aaawwwwwwww yeeeaaah boyyyyyyyyyy!
Old 02-26-2009, 11:28 AM
WOO! I can haz wire loom?
Old 02-26-2009, 11:33 AM
I was just going to say...
That looks like one angry engine bay!
Old 02-26-2009, 12:04 PM
I haven't decided if I want to cover it up yet. I might end up redoing some connections later.
Old 08-23-2009, 06:29 PM
svxash's Avatar
svxash svxash is offline
Does anyone have any sound clips of these horns?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 08-23-2009, 06:34 PM
Personally I'm not too impressed. Pitch is too high.
Old 08-23-2009, 07:19 PM
You can always unplug the high pitched one. I do find the tone a little rough. Loud and attention grabbing, but not pleasant.
Old 08-24-2009, 12:14 PM
Yeah but it loses a great deal of effectiveness with only one honker.
