Re: $5, 5 minute droopy visor fix
Well finally I am starting to experience some pull of the headliner, you might want to modify this idea by putting one of the magnets under the headliner, it will make it harder to glue though
When I got my pearlie two years ago, it was missing the driver's side visor and the passenger side was held up with velcro. The P.O. said he would fix it before I took the car, and he did, sorta. The driver's side now has a droopy visor, and the passenger side has one that stays up, but the headliner is pulled apart above it. I asked my upholstery guy if it could be fixed, and he said the fix was replacing the entire headliner. He gave me a workaround, however. A few long straight pins, the kind clothing manufacturers use to stab you with when you open a new shirt, pushed not straight up into the headliner, but back (to the rear) in the recess where the visor fits has stopped most of the sagging. The ideal thing, short of a complete (expensive) headliner replacement, would be to use some sort of hypodermic needle to inject glue between the liner and its backing. I'm looking for the right combination of tool and materials. And the driver's side liner is starting to come down, just from age, so I'm eventually going to have to find some sort of fix.
Paul
The great white fleet: '91 Alfa Romeo 164L 5-speed '92 Subaru SVX LSL '93 Mercury (Aussie) Capri |
did i not say it would pull loose the headliner? yes i did, and yes it does this over time.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Well yes you did say it would pull loose shortly, it took over a month and it started to pull a little bit. At least I'm trying something here
Just discovered another inexpensive fix. Install a 3/4 inch binder clip between the visor and side headliner trim. The black spring fits nicely between the two, with one clip slipped into the headliner trim and the other holding the visor. Enough flex to be able to pull the visor down when needed.
![]() Gene
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty ![]() ![]() 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 ![]() 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles Last edited by shelfy; 07-01-2009 at 10:13 AM. |
