Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 04-24-2009, 10:12 PM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
Re: $5, 5 minute droopy visor fix
When I got my car the previous owner had already gone the velcro route. I've since had to shore it up a little bit to make it stick better, but from all observations it's been like that for a while. And I have ABSOLUTELY NO headliner droop. None. At all. Whatsoever. If I had $150 laying around you bet I'd get a new visor. But for now my velcro mod works just fine.
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 04-24-2009, 11:36 PM
i wonder what winnebago visors look like.
Old 04-25-2009, 06:34 AM
y2daniel1981's Avatar
y2daniel1981 y2daniel1981 is offline
Not visor, but mini-blinds!
Old 04-25-2009, 07:55 AM
Green1995SVX's Avatar
Originally Posted by Brandon770 View Post
I agree to this as well. Only my car is in complete lacking of the sun viser and I have gone the rout of a very dark tent on the top of my windshield that spans down about 7 inches. Its worked pretty well but I will still be thinking of new visers eventually.
I'm confused.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-25-2009, 08:02 AM
Earthworm's Avatar
Meow!
I also removed my (non-droopy) visors and, instead, rely on a vinyl band on the windshield to block the sun for me.
Old 04-25-2009, 03:24 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Magnets are a great idea Trevor. The good lady of the house tought me that a dab of clear nail polish will prevent any unraveling of the cloth.
Gene
Gene and Ben
Old 04-25-2009, 07:36 PM
Gene
I believe the magnets were my idea...Trevor just added that maybe you could place one under the headliner cloth
Old 04-26-2009, 09:37 AM
bwb3's Avatar
Sorry, great idea y2daniel1981
Gene
Gene and Ben
Old 05-05-2009, 02:47 PM
nothing bad happening yet
Old 06-10-2009, 06:49 AM
Well finally I am starting to experience some pull of the headliner, you might want to modify this idea by putting one of the magnets under the headliner, it will make it harder to glue though
Old 06-12-2009, 09:25 PM
PaulDexler PaulDexler is offline
When I got my pearlie two years ago, it was missing the driver's side visor and the passenger side was held up with velcro. The P.O. said he would fix it before I took the car, and he did, sorta. The driver's side now has a droopy visor, and the passenger side has one that stays up, but the headliner is pulled apart above it. I asked my upholstery guy if it could be fixed, and he said the fix was replacing the entire headliner. He gave me a workaround, however. A few long straight pins, the kind clothing manufacturers use to stab you with when you open a new shirt, pushed not straight up into the headliner, but back (to the rear) in the recess where the visor fits has stopped most of the sagging. The ideal thing, short of a complete (expensive) headliner replacement, would be to use some sort of hypodermic needle to inject glue between the liner and its backing. I'm looking for the right combination of tool and materials. And the driver's side liner is starting to come down, just from age, so I'm eventually going to have to find some sort of fix.
Paul
The great white fleet:
'91 Alfa Romeo 164L 5-speed
'92 Subaru SVX LSL
'93 Mercury (Aussie) Capri
Old 06-12-2009, 09:46 PM
bheinen74 bheinen74 is offline
did i not say it would pull loose the headliner? yes i did, and yes it does this over time.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 06-13-2009, 05:59 AM
Well yes you did say it would pull loose shortly, it took over a month and it started to pull a little bit. At least I'm trying something here
Old 06-30-2009, 01:53 PM
bwb3's Avatar
Just discovered another inexpensive fix. Install a 3/4 inch binder clip between the visor and side headliner trim. The black spring fits nicely between the two, with one clip slipped into the headliner trim and the other holding the visor. Enough flex to be able to pull the visor down when needed.
Gene
Gene and Ben
Old 07-01-2009, 10:10 AM
Gene
do you have pics of where you have the binder clip installed? i can't visualize it. must be the H1N1.
