Old 05-14-2009, 01:26 AM
racecube racecube is offline
Thermostat Question
My SVX is temporaryly overheating. What should I look for before removing the cylinder head gasket? Where is the thermostat located (A picture would help).
greetings from germany to the SVX Forum by Eddy
Old 05-14-2009, 05:02 AM
Re: Thermostat Question
Follow the lower radiator hose to the thermostat cover on the lower, left side of the engine.
After draining the coolant, use a 10mm socket to remove the two bolts that hold the thermostat cover in place.
Replace the thermostat and gasket with Subaru parts.
Good luck.
Old 05-14-2009, 10:33 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
More information please. When does it overheat? While driving or while idling?
